Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 11-04-2003, 03:46 PM
Ledbet Ledbet is offline
Exclamation Fuel Pump
I have a 97 Jeep Grand Cherokee, It started to kind of spit and sputter
Like air in a water hose when you first turn on the water when I drove it. It seemed as if it was not getting gas. It did it after it was driven about 15-20 miles. It is in the 80's here not cold mornings etc. It does it at all conditions. The check engine light came on I took it to the Chrysler Dealership they hooked it up to their computer and it showed a bad CO2 Sensor. We replaced the CO2 sensor and the light went off. Seem to have no problems after that. Next few time driven I would try to pass another car and it would spit and sputter and later die. I would start it and it would run will rough a few minutes, I could go a little father then it would die again. It would do this over and over a few miles then start and run fine. The check engine light never came back on. I took it back to the dealership, they stated the fuel pump was bad. We replaced the fuel pump, they drove it a few miles it died and will not start again. They said it was a bad pump, I dont agree. They say it is getting fire and it just wont start. I feel that I am getting screwed. Please help!!!!!
CL
Old 12-21-2003, 07:40 PM
GCJeep94 GCJeep94 is offline
Re: Fuel Pump
Same thing has happened to me...with my 94 GC. I replaced the Fuel Pump, Filters, O2 Sensors, battery cables, battery, not to mention the number of times I have been towed. It usually happens if I make a 5 mile trip to the Gas Station.. It is the most frustrating experience imaginable.... Still haven't found the solution... I too await an answer.
Old 12-30-2003, 10:57 AM
snidelywhplsh snidelywhplsh is offline
Try the AIS motor on the throttle body....(IF V8)
Old 02-11-2004, 09:09 PM
Dale Aeppli Dale Aeppli is offline
Re: Fuel Pump
LOOK BACK BY FIREWALL FIND TERMINAL CONNECTOR THAT LEADS DOWN TO CRANKSHAFT SENSOR .UNPLUG IT UPON THE TOP,RECONNECT IT ,IF IT STARTS THE CRANKSHAFT SENSOR IS BAD. [email protected]
Old 04-18-2004, 04:38 PM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Re: Fuel Pump
I agree that sounds like it could be the problem.
