Old 11-04-2003, 02:26 PM
antielvis antielvis is offline
'95 Grand Am "Low Coolant" sensor
Where is the "Low Coolant" sensor located on a 3.1L (if the engine size matters)? I had to replace the heater core over the weekend, and now that I've filled it back up and it's running good, the "Low Coolant" light still won't go off.
Old 11-04-2003, 08:44 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: '95 Grand Am "Low Coolant" sensor
Take a screwdriver and use the handle and tap on the coolant res!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-07-2003, 09:18 AM
antirice's Avatar
antirice antirice is offline
it takes up to 2 weeks for the coolant sensor to reset itself after a coolant refill
Old 11-07-2003, 11:41 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: '95 Grand Am
Where did you hear that?
What happens is the senor sticks or gets an air pocket..tapping on the coolant jug right at the area of the sensor will fix the problem.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-07-2003, 11:56 AM
antirice's Avatar
really, I stopped by a garage and asked a mechanic and he said that it takes a few days for the sensor to reset itself
Old 11-07-2003, 12:55 PM
Thanks, a good little tap took care of the problem. I suppose that if you don't take matters into your own hands, maybe it can take up to 2 weeks to hit a good enough bump to have the same effect.
Old 11-07-2003, 01:00 PM
antirice's Avatar
hmm...that could be
Old 11-28-2003, 12:22 PM
Tobie Tobie is offline
Re: '95 Grand Am
I don't know if this will be of any help but I can suggest one thing. I have a 99 Grand Am and last week my low coolant light came on too, I took to my mechanic and $54 and one day later he said that I had a cracked radiator cap on the coolant resevoir. Try getting a new cap and see if that works.
Old 12-09-2003, 06:57 AM
keithan49 keithan49 is offline
Re: '95 Grand Am
Its located inside the add coolant tank. you can remove the tank with just one screw, clean it out and the send should work again.
Old 11-30-2004, 02:32 PM
kevintullos kevintullos is offline
Talking Thanks for the advice
This saved me hundreds. Thanks for posting!!! the tap the radiator tank idea was genius. It just shows usually the simplest ideas work the best. I hit it with a screwdriver several times, and the light never came back on. It was going to cost me $70 for a new tank and sensor + the labor was going to be about $250.
Thank you!!!
Kevin Tullos
