Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 11-04-2003, 12:15 PM
eightwgt eightwgt is offline
97 PU engine rattling
When I start my engine - all sounds great as well as when I shut down. When it warms up, and i accelerate, I get a rattling noise..... also after its been warmed up, anytime I accel - it rattles until I back off or level out in speed... I tried higher octaine gas... helped a little but still a little rattle. I have not put in High Octraine - only the mid line fuel....
Any help on this ???
Old 12-31-2003, 12:50 AM
Arkemn Arkemn is offline
Send a message via MSN to Arkemn
Re: 97 PU engine rattling
how many miles does the truck have its probaly your timeing chain puting higher octane gass is only makeing a bigger boom than the rattle its slef with the engine shut off not started if you do this with the engine started you will lose a finger open the oil cap use your finger to find the timing chain and gear try moveing the chain real fast if the chain moves replace it or don't it'll go about 160,000 miles before breacking or longer
Razors burn and so do tires
Old 12-31-2003, 01:27 AM
jim dillard jim dillard is offline
if you think it's ping, check the timing; sounds like a rod knock which obly major repaiur will help. how abouy some history? miles. ever run low on oil, etc?
Old 02-29-2004, 02:58 PM
shortysdrop's Avatar
shortysdrop shortysdrop is offline
My 97 clancked (30,000mi.) at start up due to timing chain tensioner recall (supposedly). Quit for a while but 20,000 mi. later it still rattles. Runs fine otherwise. This is my second 97 and I also have a 86.5. Its the only one thats ever done it.
Old 03-01-2004, 11:24 AM
a1danel a1danel is offline
Re: Re: 97 PU engine rattling
FYI, My 97 is doing the same thing, this is the second engine that I have placed in my truck. The first time I did not get it fixed and I blew the engine. Looks like this one I may have done the same thing.. This is the only vehicle I have ever had so much trouble with. I have it in the shop getting diagnosed but I am sure its something to do with the timing chain.
My recomendation, once the truck is running good sell it.. Once I get mine running right again than that is what I am doing. Especially now looking at these forum's (I thought it was just my luck)
Old 03-01-2004, 11:37 AM
Read my 300z swap idea on the other thread. That is my cure. The engine has been babyied all its life There shouldn't be any internal problems but, who knows. Its an automatic so it needs junked anyway.
