Old 11-04-2003, 10:47 AM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Automatic Launch Method
I was just wondering if anyone had any ideas on lauching a AT turbo car. Trying to shave even more time off my 1/4. Typically i put the car in 2nd with the overdrive off. Pump brakes and launch close to 3 grand. Car won't stay still much past that. At about 60 i put it back in drive and at 80 i turn the over drive back on.
Old 11-04-2003, 03:05 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
why dont you put it in low? L or 1st whatever is says on your center consol, then just shift up at redline... other than that everything is right, but dont use your Overdrive, you dont need that in the 1/4 mile, it just slows you down!
Old 11-04-2003, 06:34 PM
Re: Automatic Launch Method
Referring to the owners manual you should not go past a certain speed in a certain gear. 2nd is about 60 MPH. Right, I have just been playing around with the AT to find the right stuff.
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 11-04-2003, 06:44 PM
EclipseRST's Avatar
Banned
ya know what, rip that section out of the "owners manual" then burn it cause its no good!!! if the owners manual said drive the car off a cliff would ya do it... its not gunna hurt the car any!!! my friend has a A/T GST and he redlines every shift when he races, and he has had his car for 3 years, so if somthings gunna happen to it, it probably should have already!!
Old 11-05-2003, 12:35 AM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Get a high stall torque converter, put in L, slam gas and brake at same time, build boost, release brake.
Old 11-05-2003, 11:21 AM
duckydsp's Avatar
duckydsp duckydsp is offline
Get a M\T and you won't have any problems.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
