Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 11-04-2003, 02:27 AM
hmmmnz hmmmnz is offline
Angry 87 civic 1600si hatch fuel problems.... help
help. fuel problems on a 1987 civic 1.6i
hey any help would be appriciated..
my girlfriends car died when she was driving it, its been going fine up till now. it turns over but wont fire. im deducing it the fuel system some where but dont know if it has a in tank fuel pump or what. i took off the hose that goes into the filter and turned it over no fuel came trickling out.. am i right or is i some thing more sinester.. umm plugs are fine and are fireing. please help
Old 11-04-2003, 09:06 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: 87 civic 1600si hatch fuel problems.... help
when you say trickling out it worries me, an FI fuel system should be pretty high pressure, it could be that there is a blockage somewhere or the pump is messed.
Old 11-05-2003, 08:19 PM
1G lew 1G lew is offline
1.61 eh? where are you from?
it's prob your main relay, turn the key 2 clicks and you should hear the fuel pump prime. you could check FP but i would just listen for the pump which should be in the rear ds fender area.
or fuel pump, coil/wires, fuses and such..
also, check the ecu for codes flashing or the pgmfi light to stay on
Old 11-06-2003, 02:33 AM
grrr
i checked all the fuses inside the car.. all sweet.
umm all the dash lights go off. i can hear a psss sound when i turn on key but its coming from under the bonnet not near the back of the car (I gather that is where the pump is located.) how do i access the pump had a look in boot but couldnt see the little hatch that the pump is usually under(other brand cars) is there a fuel pump relay? where is the little bugger hiding?
im in new zealand but help is great from any where
Old 11-06-2003, 10:47 AM
NZ eh, good stuff. you ought to get me 1 or 2 little things next time your at the salvage yard. i'd make it worth your while!! [email protected]
on the problem, the fuel pump is where you said, it's under the car in ft of the drivers rear tire well. you have a FP relay it should be located under the dash. look behind the fuse box then up behind the dash. there should be a cluster of relays one of which should say main and have a 10 pin connector
here the link http://www.markl.f9.co.uk/howto/elec...main-relay.htm
Old 11-09-2003, 11:31 PM
ok releay is fine.. f*%k what a mission getting that bloody thing out. lol
ill have a look now a fuel pump. is it saposed to be pumping full time once the key is on or only when the car is running?
hey mike where do you live?? and what are you after?
they seem to be a pound a penny over here so shouldnt be too hard to find any thing you are after..
Old 11-10-2003, 12:42 AM
ok, the pump is under the car near the drivers side rear wheel. you'll see a flimsy black box that covers the pump (under rear footwell). get in there and check the pump for continuity. if it's ok, then have a friend turn the key forward and back a few times to make sure your getting 12V to the pump.
btw, when you turn the key on you should hear the pump prime for 2 seconds at the same time the car chimes twice for the seat belts.
if all this check's out and the fuel filter is not cloged then i would next test the the fuel pressure regulator. see if you can get your hands on a fuel pressure gauge, it screws right down in the extra nut on top of the fuel filter. again, check all fuses with a ohm meter... they can look ok, but..
keep me posted on the problem, you can also email me directly if ya want! i'm in NE USA (charleston, WV 25303) we'll see if i solve your problem before i get a reward! lol 2 small things prob really cheap, i'll gladly pay double plus shipping. if and when
do you have the online factory service manual? it's kinda hard to use but it's info. if not i'll dig up the link!
l8ter
Old 11-10-2003, 12:49 AM
http://www.honda.co.uk/owner/WorkshopManualCivic84-87/
http://www.redpepperracing.com/technical/
http://mirror.rivendel.nu/crxclub/cr...struktie1e.pdf
http://mirror.rivendel.nu/crxclub/cr...struktie1e.zip same but zip (i think)
cheers!
Old 11-15-2003, 02:33 PM
well i got the fuel pump going, joy on that front, still not going though,
there is current going to the plugs(i cant get plugs as i dont have right size socket) but i did put on my clamp on ammeter and there is current getting there.. so im presuming they are a go.. plugs are resonably new.
i took apart the distributor and gave all the termals a bit of a sand,
i was thinking mabee a capacitor in the dizy( but cant find it) is it part of the computor management system??
any ideas would be great,, ( remind me never to buy a car wif fuel injection) ( ill stick with my smelly old carbed soobie)
Old 11-21-2003, 12:43 AM
chevyfreak chevyfreak is offline
check your fast idle sencer it might be sticking really bad and not alowing the car to get fuel mine was doing that then it was gettign to much took me for ever to get it tooned up right.
My new Dodge
