Go Back   Automotive Forums .com Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 11-03-2003, 10:24 PM   #1
susan94civic
what to buy? monroe, tokico or KYB
Hello guys,
I new to this but I want you to know I need to upgrade my suspension. My car has over 300k miles. I took it to a performance shop and the guy told me not spend money on coil over or adjust shocks. He said that I would never going to adjust my suspension for everyday driving. He suggest that I should buy a set of Monroe for $340 and tenzo for $150.
But as I look at this forum, I hear nothing of Monroe or tenzo. Is he trying to ripe me off since I'm a woman?
susan94civic is offline   Reply With Quote
Old 11-04-2003, 12:39 AM   #2
BullShifter
BullShifter's Avatar
Re: what to buy? monroe, tokico or KYB
Only 300K miles? I say get adjustable shocks or adjustables coilovers even for street use only. Most likely you won't use them for what they were designed for but once you've upgraded non-adjustable parts, your stuck with that ride. At least with adjustable shocks you can tune your ride or tune all types of stuff with fully adjustable coilovers(bump/rebound, ride height, spring rates) to your needs. If you have the extra money to spend, go for it - make sure its quality.
How much do you plan on lowering?
Do you need ride height adjustments?
Don't buy "coilovers" unless its a kit (springs/shocks)
H&R / Koni / tein - coilovers
H&R / Eibach / Neuspeed - springs
Koni / KYB / Bilstein / Tokico - shocks
H&R Cup Kit - matched springs / shocks
For example, Eibach's Pro Kit was not designed to work with KYB AGX's, and the other way around. Having the adjustments on the shocks makes better use of these parts.
BullShifter is offline   Reply With Quote
Old 11-04-2003, 03:09 AM   #3
SilverY2KCivic
Cali Guy
SilverY2KCivic's Avatar
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
First off I'd say it all depends on how low you want it to be?
In all honesty, I'd say go with some Neuspeed Sport, or Eibach Pro-Kit springs, and then some Tokico "blues" performance shocks. They will be enough for those springs. You may not need adjustable coilover sleeves like mentioned, but then again you aren't stuck with the same right height with them either like you would be with normal lowering springs.
So how low are you looking to lower the ride height by?
Also welcome to AF.com
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
SilverY2KCivic is offline   Reply With Quote
Old 11-04-2003, 12:25 PM   #4
susan94civic
______________________________________________
Thanks for the input. I learning as I go through this forum. I do not want to go no lowering than 1" drop. From your input, I guess not to go with monroe and tenzo. I have a budget of $600 and I want the best quality parts I can buy. How about a kyb adjust with HR spring?
Old 11-04-2003, 09:40 PM   #5
BullShifter
Re: Re: what to buy? monroe, tokico or KYB
KYB AGX & H&R would be a great choice
Maisto buys HUMMER brand from GM chepp Diecast Car Modeling 2 04-23-2025 12:31 AM
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q & A 2 06-05-2009 12:18 PM
1993 Pathfinder - Worth Buying?? z4teen Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 04-16-2009 01:19 AM
Maisto buys HUMMER from GM chepp Car Modeling 1 04-01-2009 03:43 PM
