Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-03-2003, 06:03 PM
oldschooljetta83 oldschooljetta83 is offline
need to make an engine swap. HELP!!
I have a 83 jetta 1 and the engine sucks. I was trying to find out what would be the best and easiest engine to swap. Somebody told me a 94 golf gti is a great engine but i really don't know. PLEASE HELP!!!!
Old 11-22-2003, 11:54 AM
rentalboy1 rentalboy1 is offline
Cool Re: need to make an engine swap. HELP!!
I would go with a 1.8 engine from an 83 GTI. I put an 83 1.8 in my 1981 rabbit convertible and it was fairly easy. (2 guys = one weekend) The most difficult part was moving the o2 control sensor control unit over to the 81. If you don't have one, get a Robert Bentley repair manual before you start. Your Jetta should use the same fuel delivery system and this will make the swap much easier. Make sure you label all connections before you start. And READ the repair manual. I found out the hard way, you lower the engine and raise the front of the car to remove the engine.
If your current engine sucks because you want more power, then I would suggest a 16v from a late 80s GTI. You will have to take the fuel and electrical components over from the GTI to your Jetta.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
What can i do with my S2000? I want to make it a 10-11 sec. car ladeedodd S2000 11 02-01-2010 08:01 AM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Engine Swap Help Needed benson509 Cutlass Series 0 04-01-2004 03:26 AM
