Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-10-2001, 12:50 PM
LS/TURBO LS/TURBO is offline
I installig a drag turbo do i need anyhing else?
I bought an Drag genation turbo complete do i need anything else .do i need to do something to my ecu. this is what it comes with: do ineed to buy anything extra
Garret T3/T4
• Custom downpipe
• Autometer boost gauge
• Custom tubular manifold
• High flow Bosch fuel pump
• Chrome intercooler and turbo piping
• Boost dependent fuel pressure regulator
• Turbonetics Deltagate wastegate
• HKS sequential blow-off valve
• All necessary plumbing
• Front mount intercooler
• Check valves
thank you
Old 12-13-2001, 04:12 PM
pvang31019 pvang31019 is offline
yeah, you'll need some JB weld, get that return line fitted on...
Old 12-13-2001, 11:48 PM
PolySquared PolySquared is offline
damn, your lucky! I want turbo too! I give you props for having turbo.
Old 12-16-2001, 11:14 PM
eightysix eightysix is offline
Send a message via AIM to eightysix Send a message via Yahoo to eightysix
Do you have the right internals? What GEN is it?
-15 year old
Old 12-17-2001, 12:20 AM
you don't need internals utilize the drag kit or any other kit for that matter...
Old 12-17-2001, 10:38 PM
TurboType-R TurboType-R is offline
I hope you are going to rebuild your engine or it isn't going to last very long...I had to do all of thise stuff to make sure that my engine was going to live through all the power of adding turbo...
Type-R Engine rebuilt for racing by NOPI and IRA companies based in CA
Pro Series 2 Block
F-Max stage 4/5 Hybrid Turbo Kit
F-Max intercooler
F-Max fuel pressurizer
F-Max Fuel Pump
F-Max Intake
F-Max Wastegate
F-Max Intake Manifold
25% increased injector size
STR Fuel Rail
APEXi BOV
APEXi Autotimer/Harness
Slotted Rotors
Brimbo Brake Pads
Autometer Exhaust Gas Temperature Guage
Autometer Oil Pressure Guage
Autometer Boost Guage
Autometer 3 Pod Guage Pillar
Skunk2 CAM Gears
Clutchmasters 8lb flywheel
ACT Clutch System with Street/Strip Disc
Type-R Transmission
Fluidyne Radiator
Unorthodox SS Underdrive Pullies
Type-R ECU
DC Sport Short Shifter
LSD (forgot brand lol)
Tanabe Racing Medallion Exhaust
Clear Corners
Carbon Fiber Euro's
Xenon Bulbs
Type-R Shift Knob (Running out of things lol)
Pedal Covers
Kenwood Excellon CD-Player
Type-R Shoulder Pads
Custom Floor Mats
not all of it was necessary but all the motor work was...the engine will not handle the power for long if it is not rebuilt to...
Old 12-17-2001, 10:41 PM
as for ECU no need to change if it going to be a daily driver...in order to get a better ECU to work you will need a lot of time on a Dyno so it will do the best for you...otherwise it is not worth it...there are programs available for the stock ECU's to compensate for the power and all..you may want to get bigger fuel injectors though...that is what I did...it will do about the same good for you
Old 12-18-2001, 08:36 PM
b16a2si's Avatar
b16a2si b16a2si is offline
damn, thats a long list. How much did everything cost???
Old 12-18-2001, 10:13 PM
I have connections with an owner of a performance shop, and he has connections with NOPI and I got everything really really cheap...I only paid like $13,000 for it all which is unbelievable
Old 12-18-2001, 10:59 PM
mikeSONICGSR's Avatar
mikeSONICGSR mikeSONICGSR is offline
Send a message via AIM to mikeSONICGSR
How do you have a 94 TYPE-R?
Or is it a GS-R
99 Nissan Altima GXE - 5sp
00 Mercury Villager Estate
Old Cars - Last to First
07 Hyundai Sonata SE - Silver
98 Acura Integra LS - Satin Silver Metallic
04 Hyundai Accent GL - Silver Mist
03 Subaru Impreza WRX - Midnight Black Pearl
98 Acura Integra GSR - Supersonic Blue Pearl
98 Hyundai Accent L - Black
Old 12-18-2001, 11:32 PM
b16a2si's Avatar
Or is it a GS-R
I think he swapped a B18C in there.
Old 12-19-2001, 11:03 PM
dude my car is more Type-R than GS-R the only GS-R parts left in it are the body and like the interior...even that won't be that way for long...engine and Tranny are both Type-R ECU is Type-R none of the GS-R front end is left except the sway bar which won't be for long either
Old 12-20-2001, 01:09 PM
you do not need that long list of applications that you mentioned...all you really need is fuel, and the drag kit comes with a good enough fuel solution to support what most people are aiming at.
as for your setup, you should really get a standalone engine managment unit, there is no point in building a motor if you're not gonna get an standalone and fine tune the fuel and spark maps. PLus, my setup cost me about $6,000 less than that and can gaurantee me 400+hp...I haven't been on the dyno yet, but will be when I have time...
Old 12-20-2001, 04:29 PM
88LXi68 88LXi68 is offline
Send a message via AIM to 88LXi68
You shouldnt have to do internal work unless you really start cranking up the boost. otherwise 11-13psi on stock internals should be ok. (This is what I have heard)
'88 Accord LXi with some goodies
Eats 4th Gen Accords for breakfast
3Geez Member since August 29, 2000
Swap in the works
Old 12-21-2001, 11:52 PM
well I know for a fact that on a factory engine it will blow between 8-12 psi off of a turbo if it is not built...I had one....I am telling you that if you want to be safe then you will need to build it up at least some...like I said before not all of everything I have is necessary...but the engine needs to be able to handle it or it isn't going to last very long...maybe 40,000 miles or so....fuel is needed and for the most part that is really what you really really need...everything else is just really really expensive to do later like cam gears and pullies..I have well over 400 HP, but I built mine to last...you can do what you want, but I am telling what has been the best thing for making car's work the longest
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
