Old 11-03-2003, 09:15 AM
ryanstj4play ryanstj4play is offline
help with 91 integra ls
While driving the other day my wife's 91 integra ls just died while running about 60 mph the alternator is new the battery is fine and there was 1/2 a tank of gas. After she got the car to the shoulder it cranked fine but would not start.. After unhooking the battery it cranked an ran fine.. Any suggestions as what to check or replace?? she was lucky this was not a heavy travled road at that time of day.. so I need to get this fixed.. please!! any suggestions would be appreciated!!
Old 11-04-2003, 05:43 PM
beatnu's Avatar
beatnu beatnu is offline
battery cables
Old 11-05-2003, 12:46 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
Re: help with 91 integra ls
maybe the coil? hows the distributor look?
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 11-06-2003, 11:00 AM
1600cc's Avatar
1600cc 1600cc is offline
Re: Re: help with 91 integra ls
Umm, maybe you should try cleaning the battery terminals. My dad had that problem with his Transport and found out that it was the terminals. Hope that helps ya...
one turn and the whole world shifts...
Old 11-06-2003, 11:30 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Hmm... he said it cranks though.
if it was the terminals wouldn't it not crank though??
check distributor, spark plug cables.
oh yeah...
this may be different with honda but i once had a neon that would randomly die on me, but would crank fine, sometimes it would start sometimes it would just crank and crank and never start, and sometimes i would be driving and it would just die.
well it drove me friggin crazy. turns out that there was a plug in the wire going to the fuel pump, and due to vibrations or something it came loose and didn't have a good connection, so sometimes it would make contact and start, and sometimes it wouldn't, and sometimes it would lose its connection while driving therfore shutting off my fuel supply.
Once i found it and plugged it back in nice and tight the car was fine.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 11-06-2003, 03:23 PM
good thoughts but
keep in mind that unhooking the battery terminal makes the car start again... so I don't think it would be the plugs or distributor would it? Nor a wire leading to the fuel pump.. Those would not be correct by unhooking the battery would they??
Old 11-06-2003, 03:48 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: good thoughts but
the same symptoms happened to my bro's 89 crx a while ago, we thought it was the battery, then the alternator and ended up replacing both before discovering that the rotor in the distributor had come loose, with that particular design the shaft that the rotor is on does not have a keyway, just a set screw so if the screw comes loose it spins free, if that is the same design on your integra it could very well be the same problem, if that is the case put some prematex on the screw so it wont happen again, because with my bro it did about a week later
Help with my 1990 z32 na aaanthony 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 01-08-2011 01:24 PM
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 12:32 PM
Need Help With Integra!!! movieprops Integra 2 03-22-2006 09:37 PM
Need help with Integra LS spitfire19 Integra 14 05-17-2004 07:16 PM
need help with Integra wings west body kit IntegraTypeRS Integra 0 02-22-2002 03:53 PM
