Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-03-2003, 06:40 AM
countryboy9799 countryboy9799 is offline
87 bonnevile with valve train noise?
Hi, I have an 87 bonnevile with the 3.8 and it just started making a ticking/rattleing sound that I think is coming from below the coil. We took the valve cover off and it didnt appear to be a lifter problem and the valves appeared to be working. My father in law said he thought it was the timing chain, can anyone tell me if that motor/year has had any problems? Also what should I be looking for? It has idled rough for a few years and the noise is a lot worse at idle, when you rev the motor just a little it quiets down to a slight tick. Thanx in advance.
Old 06-09-2004, 05:34 PM
norconian2001 norconian2001 is offline
Re: 87 bonnevile with valve train noise?
Did you ever get a response to your concern.I have a 1990 Bonneville that is doing the same thing. I started to remove the valve cover to see if there were loose parts but had to stop. My car has over 200,000 miles and I don't want to spend a lot of money for repairs. Thanks in advance.
Old 06-11-2004, 12:14 AM
carnutcass's Avatar
carnutcass carnutcass is offline
200,000 miles.....holy cow. Did you buy the car new? If you did, and you've never changed the timing chain....well, you're WAY overdue.
2002 Altima with a lot of valve train noise 96CamaroSS Altima 0 04-23-2009 08:50 PM
valve train noise (clatter) jdedgewood '97 - '03 4 12-30-2004 09:11 PM
Valve Train Noise Schoolbuilderbob SC/SL/SW 4 11-03-2004 10:20 PM
3.2 hydraulic valve train noise Kevin Mac Rodeo | Passport | MU 6 09-01-2004 06:16 PM
VR6 Valve Train Noise Bob Dutton Jetta/Vento/Bora 0 08-19-2003 03:12 PM
