Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 11-02-2003, 05:48 AM
Crusader121 Crusader121 is offline
Question Another HICAS ?
Okay, I have a 91 R32. Please tell me if I'm right or wrong. With this HICAS system, I know their are a lot of sensors and if one these sensor goes bad somwhere it will create a lot of chaos for the HICAS system, but it should not cause the power steering pump to stop working. As of right now my idiot light is on and the power steering is not working, wich means the HICAS is not getting fluid and is tripping the idoit light. I have tried to get it to go into diagnotics and have not been able to get it to work. My conclusion is that I need to go down to the local junk yard and replace my power steering pump. If any one has any other ideas please help before I hit the junk yard. Oh the skyline drives normal except I have to use a little muscle around the tight corners.
Old 11-02-2003, 11:29 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Yo D,
While your at the junk yard, can you pick me a couple of reverse light covers, the ones by the licence plate. My wife backed into something, and busted them on my R32.
And yes, you are on the right track.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-15-2004, 09:05 PM
GalEVO GalEVO is offline
Re: Another HICAS ?
Anyone?? any idea where is the Steering ECU?
My HICAS lite is lited!!??
Old 11-15-2004, 09:27 PM
matada's Avatar
matada matada is offline
Send a message via AIM to matada
Re: Another HICAS ?
Actually, first thing you should do when you hicas light starts acting up is to check you alternator voltage and your battery. This is the most common contributing factor to the hicas light. I rarely have to change computers for this, but quite often the alternator can over-charge or under-charge, resulting in the problem you are experiencing.
Try the battery first though, as weather and temp changes will affect them the most. A battery for a skylin costs less than 20 bucks anyways for the 40B19L.
Count em.....
matada19: she die?
OoToksinoO: no, unfortunately
matada19: damn
OoToksinoO: cant win em all man
matada19: can i sig that?
Old 11-15-2004, 10:11 PM
Re: Re: Another HICAS ?
Ok.. I'll get my mech to check to voltage..
hopefully I really do not need to change the comp is really costly!! (SDG 7k!!) ..
BTW u know where the Steering ECU is located?
Old 12-03-2004, 01:33 AM
juzy juzy is offline
Re: Another HICAS ?
the hicas computer is in the boot under the parcel shelf
Old 12-03-2004, 01:42 AM
my3rdskyline's Avatar
my3rdskyline my3rdskyline is offline
Send a message via AIM to my3rdskyline
Re: Another HICAS ?
it's the square one. if you see two things under there the round one is your rear speaker amp and the square one is the HICAS
Old 12-03-2004, 02:59 AM
thegladhatter's Avatar
thegladhatter thegladhatter is offline
Re: Another HICAS ?
Next time take a bigger picture. That one is too hard to see.
Mr. Congeniality and PROUD Infidel!
Old 12-03-2004, 04:40 AM
Re: Another HICAS ?
