Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-01-2003, 11:38 PM
Slitha Slitha is offline
Question 323 Engine Replacement
The engine on my 323i (E30 1985 Auto) got the death-rattle last week so its time to replace it .
This morning I removed everything so that the engine can be extracted. So far so good, until I discovered the hidden bolts holding the bellhousing on . I was expecting to remove the engine without the transmission attached. My question is whether it is possible to remove the engine without the transmission - if so how ? Or is there a standard procedure to follow for removing both ?
I'm figuring I might have to pull engine+trans out a little way, remove the bolts, then pull the engine out the rest of the way. Any problems with this ? Should radiator be removed or is there enough room ?
Thanks for any help you can provide.
Adrian.
aka Slitha (the registration plates for my Cobra)
Old 11-03-2003, 10:41 AM
Audi Ryder Audi Ryder is offline
Remove the bolts out of the flywheel and the bell housing. Pull out the engine. It is advised that you remove the radiator and a/c condensor before doing so. More space
Old 01-06-2004, 08:25 PM
Well I did it. New (or at least 2nd hand) engine is in and running. In the end, I cantered the engine+trans back at an angle and got a very long socket extension to access the bolts at the top of the bell housing. I ended up just disconnecting the hoses to the a/c condensor & power steering pump but left them dangling on wires. Radiator was removed but left the a/c one in. Trickiest bit was unthreading the wiring loom & putting the engine back in by myself.
If anyone needs more info, just let me know.
Adrian.
