Old 11-01-2003, 09:20 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Audiobahn ALUM series
These subs are dual 6 ohm voice coils, now I am at a loss as how to wire them together, I have two of them. Is it like wiring a normal amp this way? how do you know amps can handle this power, etc?
Old 11-01-2003, 09:26 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Audiobahn ALUM series
with 2 dual 6 subs you can wire them to : 1.5ohm, 6ohm, 24ohm
Find a 1ohm stable amp that puts out 50% more power than you need at 1ohm
say you needed 1000 watts between the 2 subs, then get a 1500x1@1ohm amp
1500 watts @ 1ohm = 1000 watts @ 1.5ohm
^ just an example so you can see what I mean by 50% more power than you need ^
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-01-2003, 09:35 PM
Haibane's Avatar
Re: Re: Audiobahn ALUM series
Also, what do you guys think of Aluminum cones, that is kinda weird to me personally
Old 11-02-2003, 02:57 AM
sr20de4evr's Avatar
Re: Re: Re: Audiobahn ALUM series
well I'm not a fan of Audiobahn in general so...
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-02-2003, 07:19 AM
Haibane's Avatar
Re: Re: Re: Re: Audiobahn ALUM series
Yeah, wouldn't expect you to be, but I like their sound
Old 11-02-2003, 01:32 PM
Haibane's Avatar
Re: Re: Re: Re: Re: Audiobahn ALUM series
I am just wondering, what would be the ideal way 2 push 2200 watts(total or less) to two of these 6 ohm DVC subs?
Old 11-02-2003, 04:58 PM
loismustdie loismustdie is offline
yeah not many people are a fan of this brand, but i have heard a horror story about these subs on my other forum.
this one guy had one alum sub pushed at its rms, whatever it is, and after about 2 hours the sub's cone melted, i dunno how to explain it. if were you i wouldn't have chosen these subs, but if you like the sound i'm not gonna tell you what you like, its all a matter of opinion. all im saying is be carful the first couple of times you run them you might want to check up on them every 15 to 30 minutes. i really don't have any advice to you except to wire each sub itself in parallel, then parallel the two subs, if that makes any sence whatsoever.
Old 11-02-2003, 06:46 PM
Haibane's Avatar
yep it does
Old 11-02-2003, 10:23 PM
ssjwizard ssjwizard is offline
Send a message via AIM to ssjwizard Send a message via Yahoo to ssjwizard
you could allways get two sepirate amps with 2 ohm ratings wire them to 3 ohm each sub. possibly not the best way to wire them but could be cheeper in some situations to get a pair of mid/high watt amps vs 1 verry high watt amp
Old 11-04-2003, 07:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the aluminum cones are a good idea in theory, they are light and rigid. Although some companies (including audiobahn) have had problems at times in keeping the surround glued to the aluminum cone
$6,000,000.00 BMW 2002 Series WKMilton 2002 1 01-21-2011 12:08 PM
SICC Drag Series/Car Show Presents Battle of the Belts - September 11th, 2010!!! nyce1 Drag Racing 0 09-04-2010 11:31 AM
anybody with audiobahn AS series speakers 94tegRS Car Audio 5 02-04-2004 08:05 AM
E36-Alum dash kits? Russ 3 Series 1 11-28-2001 09:43 AM
97' E36- alum. dash trimkits? Russ 3 Series 0 11-14-2001 11:12 AM
