Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-01-2003, 06:04 PM
amfrff amfrff is offline
Won't Start
I own a 1991 Jetta that was driving fine. All of a sudden the oil light comes on and stays on. The oil is fine. But, then the car just fied and will no start now. It does crank. This is no spark coming from the coil. I did replace the coil but that did not help matters. If anyone has any insight please help.
Thank You
ann marie
Old 11-05-2003, 09:31 AM
bjk1159 bjk1159 is offline
Question Similar problem
I am have the same problem with my sons 86 GTI. His alternator went out and took something with it. After replaceing the alternator we have no spark. We have replaced nearly everything but nothing seems to help. If you find out whats wrong with yours will you let me know and I will do the same. Obviously nobody has a clue in this forum. I have received some pretty strange replies to my thread. Thanks, Brad
Old 11-05-2003, 03:05 PM
K_millar K_millar is offline
Maybe you should address the original problem. Check the oil pressure sensor, or maybe the oil pump has failed and some safety mechanism has engaged.
I don't know anything about VW's, but thats my 2 cents.
KMillar
Old 11-23-2003, 10:16 AM
We finally resloved the same problem in my son's 86 GTI. It was the knock sensor control unit. I am not sure if you car has one as the Golf doesn't but the GTI does. We took it to a mechanic who looked at it for a week and could not figure it out so I went online and found a siye that has VW Schematics. Turns out that the distributor goes directly into the knock sensor control unit. We bypassed the KSCU and wired it like the Golf and Waa Laa spark. If you do not have a knock sensor I would check the Ignition module. ours is locate on top of the ECU under a plastic cover in the back of the engine bay. Hope this helps.
Old 11-28-2003, 03:58 PM
Stoney-S8- Stoney-S8- is offline
Re: Won't Start
How about posting a link to that schematics site please.
Old 11-28-2003, 06:11 PM
Here is the link I used. http://www.rlocman.com.ru/en/out.htm?cg=8&fs=0
Old 11-29-2003, 10:17 AM
thanks a lot bro i apprecciate it, and i'm sure everyone else does too
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-02-2010 11:37 PM
99 Regal LS stalled now won't start mfraumeni Regal 7 04-05-2010 12:38 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 09:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
