Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 11-01-2003, 09:30 AM
LateNightJoeB LateNightJoeB is offline
Unhappy Chrysler New Yorker Brake Problem
When I apply the brakes, the pedal goes practically to the floor before stopping the car. I filled it with brake fluid. Seems a tiny bit better but not too much better. No leaks that I can see. If it were a leak would brake fluid be under the car? What would the possible problem be? If it is a few things it could be, what are they? It's driving me crazy cause other than this, the car looks and drives like a new car. Please help!!!!
Old 11-08-2003, 02:34 PM
proticus's Avatar
proticus proticus is offline
have you tried bleeding your brakes? air in the lines would cause it to feel spongy and take extra effort.
Old 10-27-2004, 10:17 PM
CHRISHARVARD CHRISHARVARD is offline
yeah my 1990 New Yorker also has the same problem. It feels like theres no master cylinder! :-(
Old 11-01-2004, 11:42 AM
rwood13 rwood13 is offline
Re: Chrysler New Yorker Brake Problem
check for leaks in the system, bleed the brakes!, buy a manual, if it does not have a prescribed method start with the wheel farthest from the master clyinder and work to the closest, you may have to do this 2 or 3 times per wheel, if you can't gety a good pedal than it may be a master cylinder, if the face of the power booster where the master mounts is wet with brake fluid, don't bother with the bleed until you replace the master
Old 12-19-2004, 04:58 AM
mikalik mikalik is offline
Send a message via MSN to mikalik
you do have good brake pads, right? (or shoes)
Old 01-07-2005, 11:48 AM
countryboy97504 countryboy97504 is offline
Send a message via Yahoo to countryboy97504
Lightbulb Failing brake problem
I agree with bleeding the brake system, and if you do not notice any leaks from behind the wheels ( or from wheel cylinders if visible ) or at the Master cylinder, then my next option would be to check for a damaged diaphram in the vaccum assist behind the master cyclinder, or seals inside the the Master cyclinder, which allows oil to bypass rather than develope pressure.
Old 06-04-2005, 04:54 PM
squiggy2005 squiggy2005 is offline
Re: Failing brake problem
Here's one for you. We replaced the whole braking system, some stuff from a junkyard but most stuff new, the car originally have the brakes fail while driving, we replaced the wheel cylnders and calipers with new ones, we replaced all brake lines. problem not fixed, no brakes, we replaced the proportional valve with a used one, didn't fix the problem, we bought a new master cylinder, didn't fix it either, we replaced the vacuum assist, still no brakes, we picked up another used master cylinder anf finally we got brakes but only when the car is not running. We have great brake pressure. Start the car and the brake pedal goes right to the floor. We tried bleeding the brakes many different times and many different ways. Anyone have any ideas?
Old 06-07-2005, 03:19 AM
E38_Charger E38_Charger is offline
Re: Re: Failing brake problem
Firstly did u try reseting proportioning valve and when the brakes are applied is it easy to lock them up? cos if it is there should b a small rubber disc inside the booster when u take off master. Get a torch and look in the hole, in the center there will be a black rubber (not metal) if there is no rubber then that will be the problem. It is about 1 centimeter thick and that on the pedal is almost to the ground cos of mechanical advantage.
I hope this helps. Also u should start your own thread so that people that have already read this one dont over look it.
1996 Chrysler New yorker stalling problems friscogirl72 General Discussion 3 02-16-2010 01:29 PM
1988 New Yorker brake problem kapp0 General Discussion 2 01-13-2010 08:48 PM
1962 chrysler new yorker brake problems paac Classic Cars 7 10-28-2008 10:28 AM
1990 chrysler new yorker shifter problems. kevn83 General Discussion 3 03-19-2008 02:34 PM
1988 Chrysler New Yorker Electrical Problem linda38 General Discussion 3 12-19-2004 06:05 AM
