Old 10-31-2003, 10:25 PM
CivicWarrior CivicWarrior is offline
Send a message via AIM to CivicWarrior
valve cover help
i was wonderin if i take my valve cover off is there anything i need to replace b4 putting it back on? like a seal or summin?
thanks
-Demo
I rip cats quick..i mean..i'll tear up ya whole style n'..
..i'm the biggest thing to hit the streets since racial profilin
Old 10-31-2003, 11:34 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: valve cover help
There is a set of gaskets under it. It won't hurt anything to change them. They go around the edge and ring each spark plug tube.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-01-2003, 02:36 AM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
well, you're supposed to buy a new valve cover gasket, but usually don't have to unless it's the original gasket or something.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 11-02-2003, 02:12 AM
jkw1689 jkw1689 is offline
Send a message via AIM to jkw1689
I always put atv sealant, for high temps, on the surface, because the Haynes manual says to put it on. Unless the old gasket is messed up I wouldn't replace it, but if it looks old just go ahead and replace it.
Old 11-02-2003, 08:35 AM
91civicDXdude's Avatar
silicone is a rig job. dont use that crap.
