Old 10-31-2003, 06:39 PM
crxinw/b20turb crxinw/b20turb is offline
please help!!!!!!!!!!!!!!!!!!
at what level of performance(horsepower) do you have to up grade to 93 or better octane. Im building a weekend racer and im trying to come up with my set up.
Old 10-31-2003, 06:57 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
if your building anything, run it. it only helps things, dont worry bout what perfermance level you are at, or what HP's you are running.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-31-2003, 09:51 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: please help!!!!!!!!!!!!!!!!!!
It doesnt matter what "level". What matters is what you are doing. If you really have a B20 turbo, you should have already been running on premium fuel.
Old 10-31-2003, 09:57 PM
shylock's Avatar
shylock shylock is offline
Send a message via ICQ to shylock Send a message via AIM to shylock Send a message via Yahoo to shylock
YUP!!!!!
In my 88 hb I run 93...it gets better gas milage and seems to run better...and thats just a d15.
In my 93 integra...all I run is 93....and I am very happy with the gas milage and performance.
Anything less than 93 and its a waste.
Old 10-31-2003, 10:15 PM
kris's Avatar
Originally Posted by shylock
YUP!!!!!
Im my 93 integra...all I run is 93....and I am very happy with the gas milage and performance.
Yeah, a waste of money.
The octane rating of gasoline tells you how much the fuel can be compressed before it ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio, or changing the spark timing, of your engine determines the octane rating of the gas you must use in the car. So a high compression ratio requires higher-octane fuel. Or, for instance, if you have your timing advanced. It doesnt mysteriously give you better gas mileage.
Old 10-31-2003, 11:27 PM
shylock's Avatar
"It doesnt mysteriously give you better gas mileage."
Hmmmmm.
I dont think I said it mysteriously gives you better gas mileage????
I stated that in hondas and acuras I (Im not sure of anyone else..) but I have owned in the past (along with other high performance autos)knock and ping less with 93. I apoligise if I mis represented what I was trying to convey. Next time I will go out and search the textbook answer....when someone asks someones opinion.
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
The name "octane" comes from the following fact: When you take crude oil and "crack" it in a refinery, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels. For example, you may have heard of methane, propane and butane. All three of them are hydrocarbons. Methane has just a single carbon atom. Propane has three carbon atoms chained together. Butane has four carbon atoms chained together. Pentane has five, hexane has six, heptane has seven and octane has eight carbons chained together.
It turns out that heptane handles compression very poorly. Compress it just a little and it ignites spontaneously. Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
During WWI, it was discovered that you can add a chemical called tetraethyl lead to gasoline and significantly improve its octane rating. Cheaper grades of gasoline could be made usable by adding this chemical. This led to the widespread use of "ethyl" or "leaded" gasoline.
is that better???????????????
Old 11-01-2003, 06:38 PM
kris's Avatar
