Old 12-09-2001, 11:47 PM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
Engines dressing?
Could somebody share tips and hints for custom engine dressing (adding plug wires, hoses, etc for more natural look)
Old 12-09-2001, 11:57 PM
Jay! Jay! is offline
Horizontally Opposed
Warren explained part of it:
Originally posted by primera man in 1970 Dodge Challenger Is My Next Project
The engine wiring is fairly easy to to.
I have a small drill that i use to drill the dissy cap. Cant remember the size but it has to be small enough to get the 8 holes in the top of the dissy cap. The heads on the engine you drill as well were the plug goes.
You then wire the engine the same as a normal engine. The wires are glued in by super glue. You just mold them to where ever you want to run them.
The fuel line i use a clear tubing that Tamiya supply in there bike kits and superglue it to the inlet of the carbs.
I use the same wiring but different colours to run to the starter motor/battery and the Alt.
Once again just drill the hole, poke the wire in.
The wiring i get from my local model shop. Comes in a red/black/green/blue or yellow.
It has a very very thin piece of copper that helps to shape the wire.
In most show cars 99% of the wiring is hiden to give a nice clean look, so you dont have to do to much
Hierarchy of Subaru:
(Click to see mine!)
Old 12-10-2001, 01:17 AM
but how to simulate crimped and rubber hoses?
e.g. like this
Old 12-10-2001, 02:11 AM
primera man's Avatar
"P-Man"
My model shop here used to sell*Dress up Kits* for engines that had all that kind of stuff in them. I'm not sure if they still do them as i have not seen one for a long time. I'll see if i can find out a bit more info for you.
The pic below was one i brought for this engine a while back
View All My Models Here.
Old 12-10-2001, 03:27 AM
Guiddy's Avatar
Guiddy Guiddy is offline
e.g. like this
That's a spring through heatshrink!
Old 12-10-2001, 03:40 AM
Sorry what is "heatshrink"?
So can I take small spring from the pen and lead it thru
small rubber hose and get such results?
Old 12-10-2001, 06:05 AM
Guiddy's Avatar
Heathshrink is a tube of a certain diameter, which when exposed to heat from a hair dryer, shrinks!
You use it in electronics. Get it from a model race car shop or electrical suppliers! Comes in lovely colours!
Old 12-11-2001, 06:24 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
Talking
Replicas and Miniatures of Maryland sells resin distributor caps already drilled-they save alot aggrevation !
Old age and treachery will overcome youthful exuberance everytime !!
Old 12-12-2001, 01:33 AM
I know they (and others) make 8-plug distibutors, but do they also make 6- and 4-plug sets, too?
Old 12-12-2001, 05:40 PM
modelfan1's Avatar
are there 4 and 6 cylinder cars. LOL
but no Norm does not make 4 or 6 cylinder distributer caps
