| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
I have a 98 civic ex coupe with a b16a2 in it and I was going to go turbo, but lately I have been thinking of getting a charger instead...I think that it would be cheaper and maybe even better, but I am not sure. Could you guys help me out....snail or charger...I really like the sound of a turbo, but if the charger is better I will go with that.
Let me know what you guys think! I was going to go with a Garrett T3/4 snail, but now might go with a Vortech charger...which do you think is better? Thanks! turbo charger
1998 honda civic ex b16a2 AEM intake HKS HiPower Exhaust Skunk2 front camber kit 2000 Si rear bumper 99 Si wheels pioneer p9000 head unit jl audio w6 12" sub Rockford Fosgate 250x2 amp 976 Crew |
Re: Turbo or Supercharger
Definitly go with a turbo. Superchargers are good becuase they always have power on demand but in the long run turbo's are more upgradeable and they give you all the cool sounds. As for price wise, you can get a turbo kit that costs way less than a supercharger. You could even put your own kit together.
ZC Crx ready for the HMT kit. |
Re: Re: Turbo or Supercharger
A vortech like he is thinking of does NOT always have power on demand. In fact, it's quite the opposite. A vortech makes boost proportional to RPM's. If you have a kit pullied for 10 pounds of boost, it makes 10 pounds of boost at redline. At say 4000 RPM's where a medium sized turbo will be making all 10 pounds of boost the vortech might be making 2 or 3 pounds of boost. If you're thinking of a roots blower, sure, it will have full boost pretty much anywhere from around 2000 RPM's and up, but they are not nearly as efficient as turbos and centrifugals, take more power to turn, and are harder to intercool, not to mention top end boost drop that you always get. Heres a little chart I made to show you what I mean.
Re: Re: Re: Turbo or Supercharger
nice chart
Need webdesign? I can help ==> 2design.da.ru |
Thanks for the chart that clarifys it and anyone who would go with the vortech is a dumbass and that is why I had to ask someone....because I could have made a horrible mistake! Thank you.
About a kit...I have on in mind that my buddy had: - Garrett t3/4 snail -tial wastegate 35mm ( I think) -HKS type S BOV -Spearco front mount intercooler -custom pipes -thermal turbo exaust...But I think there is a A'pexi N1 turbo exaust, isn't there? If so then I will get that. -cusco racing clutch just a starting list of the basics...tell me what else I need if I forgot anything....I was also curious about how much all this is going to cost. Thanks a lot guys!
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
heres another from a civic si. what im trying to point out with these pictures is that the gains aren't really significant till later in the higher rpm range and if u look closely these guys aren't even starting at 2000 rpm. so in other words the s/c should start of stronger, but later on the t/c should catch up, then pass the boost for the sc.heres one of their stage three just for the heck of it and look at the lag on this thing! now im not trying to call ur chart bs since it does make sense if that was a really small turbo, but with a small turbo theres really not much hp gains. i just think u should give a better representation of each, although if it was me i would go turbo all the way whether turbo lag or no turbo lag. reason 1-achieve more hp gains reason 2-its creating power out of waste, unlike the the sc which is using power from the crank to make more power. reason 3-the blow off valve sounds really freaken cool, although its porpose is bad, but a good kinda bad if u know what i mean.
Re: Re: Re: Re: Turbo or Supercharger
The reason his graph looks different than your three is because he plotted boost vs. rpm. As you said your friends gsr makes full boost at about 4500 rpms. On his graph full boost doesn't come until 4100. The reason your graphs seem to rise more slowly is because alot of the high revving engines we love don't make max power until high up in the rpm band. So with a constant amount of boost, it should be the same shape as a stock motor.
The graph I made was a general rough estimate, I didn't take any actual data and plot it, it was just to give you a rough idea of what the boost curve might look like. In all honesty, the first few charts don't tell you much about the spool characteristics of the turbos, because how quick the turbos spool and how much power they make is totally dependant on how well the car is tuned. If your friends GSR isn't making full boost till 4500 with a smaller turbo, something is wrong. I'm running an SC61 .60 A/R compressor .63 A/R exhaust stage 5 wheel and i'm starting to make boost at around 3400-3600, and I have 1 bar by 4300.
Does anyone know about how much this kit will cost?
Re: Re: Re: Re: Re: Turbo or Supercharger
. What im tring to explain is that all turbos have lag time, u don't just press on the gas and boom your at full boost. it takes a sec or 2 before enough exhaust can spool the turbine at the desired psi. with the supercharger there is no wait since its in constantly motion with the engine, although u won't get good hp results as with the turbocharger.
with my friends gsr, he has a rev hard stage 2 (medium) turbo thats why it takes longer to spool, but i bet he can bring it down some if he tune it up correctly. still there is going to be the dreaded turbo lag which a supercharger doesn't have to deal with.
Re: Re: Re: Re: Re: Re: Turbo or Supercharger
In your first post you said that In his graph it looked like boost came up really quickly. If you look at the graph you will see that full boost isn't made until around 4000 rpm's. This seems pretty "laggy" to me.
