Old 10-31-2003, 01:39 AM
rspecht rspecht is offline
Disassembly of Left Rear Interior Panel
I need to get behind the left Rear Interior panel, adjacent to the third seat on a 2002 Town and Country (assume that this is the same for a Caravan).
How does this panel disassemble?
Old 10-31-2003, 10:23 PM
tazman tazman is offline
Re: Disassembly of Left Rear Interior Panel
You have to remove both the scuff plate and the header at the rear of the van. Using a 9/16 socket, undo the upper seatbelt bolt next to the window. From the bottom of the 'D' pillar (interior panel) gently pull it an inch or so away from the side. There are 3 plastic push-pins holding the pillar to the body so use a long pair of needle-nose to wiggle them out. When they are out wiggle the pillar back and forth to release the last clip at the top of the pillar. I hope this helps you out.
98GCL-How to remove left rear trim panel? DPServices Grand Cherokee | Grand Cherokee SRT8 2 10-16-2006 07:25 AM
Need help removing rear interior panels to fix annoying vibration Troy84 Blazer 0 08-24-2006 12:33 AM
?? Rear Interior Panel removal on 1990 st?? skaterblader23 Celica 6 01-16-2005 05:44 PM
left rear quarter panel fishlips34 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 11-29-2004 01:51 AM
Looking for a '93 left Rear Quarter Panel RocketPowerParts 4Runner/GX470 1 07-07-2004 06:26 PM
