Old 10-30-2003, 09:56 PM
1SickZC's Avatar
1SickZC 1SickZC is offline
Send a message via ICQ to 1SickZC
MPFI swap problem
ok. got the swap done, brand new harness, everthings hooked up right, but when i start my car it instantly revs to 5000 and stays there!. noiw we took out the injectors and one was stuck open..... would this cause this problem?... let me know. thanx
Old 10-30-2003, 09:59 PM
MaXXuS's Avatar
MaXXuS MaXXuS is offline
Re: MPFI swap problem
Did you switch the outer wires on the TPS??? That is probably it, unless your idle is way screwed up..or a huge couple of vaccum leaks?
Old 10-30-2003, 10:07 PM
gsf1200m gsf1200m is offline
I'd say a vacuum leak.
Old 10-30-2003, 10:08 PM
1SickZC's Avatar
all very possible...... i think the TPS was looked after... but the other 2 r very possible.. i'll mention this to the guy doin my work... hopefully all goes well...... thanx
