Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-30-2003, 09:48 PM
qfisok2me qfisok2me is offline
SAble '96 Overdrive light blinks when the overdrive tries to kick in
Does anyone know if the repair is expensive? When it is time for the overdrive to kick in, the light comes on instead. It just stays in fourth gear.
Old 11-02-2003, 11:08 AM
OAKRAID OAKRAID is offline
Re: SAble '96 Overdrive light blinks when the overdrive tries to kick in
You need a valve body clip.. gasket,,,tranny fluid and filter.
Remove left front tire..splash shield.. remove tranny mount then
remove valve body cover then valve body...repllace broken clip
then reinstall components...change fluid and filter all is well
took me aprrox three hours
Old 11-09-2003, 09:30 PM
OK, thanks. And this will fix the overdrive light? I will have to do that. What is the specific name of the part I need?
Old 11-11-2003, 07:41 PM
Re: Re: SAble '96 Overdrive light blinks when the overdrive tries to kick in
A/T - AX4N No 4th Gear/DTC's P0734/P0761/648 Set
Article No.
98-10-7
05/26/98
^ TRANSAXLE - AX4N - NO 4TH GEAR AND
DIAGNOSTIC TROUBLE CODES (DTCS) P0734
AND/OR P0761 FOR 1996-98 TAURUS/SABLE AND
1995-98 CONTINENTAL, AND DTC 648 FOR 1994-95
TAURUS/SABLE
^ TRANSAXLE - AX4N - RETAINING CLIP FOR
FORWARD CLUTCH CONTROL VALVE - SERVICE
TIP
FORD:
1994-98 TAURUS
LINCOLN-MERCURY:
1994-98 SABLE
1995-98 CONTINENTAL
ISSUE
No 4th gear operation (no 3-4 shift) and Diagnostic Trouble Codes (DTCs) P0734 and/or P0761 or 648 may occur on some vehicles. This may be caused by a broken retaining clip in the valve body that secures the forward clutch control valve and spring in place.
ACTION
Replace broken forward clutch control valve retaining clip with revised forward clutch control valve retaining clip. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Inspect for a broken retaining clip by removing the valve body and then the valve body separator plate. Inspect the forward clutch control valve, spring, retaining clip, and valve body casting for damage (Figure 1).
2. If the clip is broken and the forward clutch control valve and/or valve body casting is damaged, replace the main control. The retaining clip has just been revised to prevent the chance of breakage. The revised Retaining Clip (F8DZ-7F194-AA) has circular cutouts on the side of the clip in place of the square cutouts on the previous design level clip (Figure 2).
3. Inspect the new main control (if required) before installing it and replace this retaining clip for the forward clutch control valve and spring if it's not the new design (Figure 2).
4. Any time service is required on any AX4N transaxle main control, inspect the retaining clip for the forward clutch control valve to be sure it is the latest design level, and replace the retaining clip if it is not. The revised clip is larger and will remain centered in the valve body casting groove.
PART NUMBER PART NAME
F8DZ-7F194-AA Forward Clutch control valve
F8DZ-7F194-AA Retaining Clip
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
981007A Inspect/Repair/Replace 2.4 Hrs.
Main Control Valve Body
DEALER CODING
CONDITION
BASIC PART NO. CODE
7F194 01
OASIS CODES: 501000, 502000, 503000, 503300, 503400, 504000
Old 11-24-2003, 10:56 PM
THANKS!!!! Will fix and report the results
Old 03-10-2004, 08:04 PM
jorgegudino jorgegudino is offline
thanks oakraid for your help about 96sable .
I have fix the problem on my transmision regarding the overdrive light blinking & shifting.Thanks again.
Old 06-13-2007, 10:44 AM
darkman126 darkman126 is offline
I'm having the same problems checked all fuses they were fine. I unhooked the neg cable fixed or so I thought for a moment anyways. now doing the same thing. I don't think this is in the transmission meaning new one I still think it is an electrical issue. my only other problem is oil consumption I Like the car and as I am retired can't afford a new car any help would be a blessing.
