Old 10-30-2003, 08:15 PM
gewebb gewebb is offline
Unhappy security 99 blazer
99 blazer. In an attempt to install a remote starter, things went wronge. After measuring the ohms from the org/blk wire to the yellow and rewiring them to theirselves. my truck would not start. I believe i messed up the calibation on the pass lock by having the key in the ingition. And from there, locked the system up by trying to start it to many times. My driver door doesn,t unlock electricly. The dome lights do not come on. the fog lights do not come on. My keyless remotes do not work. I only installed the pigtail of the remote starter, never hooked up unit. All pig tails are now out and the wiring is back the way it was. I did not cross any wires either. PLEASE HELP ME. Will resetting the computer do it, and if so how do i do it?
Old 10-30-2003, 09:30 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: security 99 blazer
Dude. Seriously, what were you thinking? Who told you that you could install this thing??? What is it? Some Bulldog unit that is barely a good paperweight?????
Sorry, I just hate it when people are told they can do this themselves. Passlock, hook the wires back up the way they are suppose to be then turn the car to the run position. The security should eventually turn off so you can start it. Next time, buy a DEI part#555l. It self learns the codes and is virtually problem free.
As far as the rest of your problems, sounds like you have blown a fuse or unplugged the keyless unit under the dash. Check fuses both inside and out next to motor.
