Need help on the replacement of the driver side HLA. Thanks
i know its best to remove the front bumper
then for the headlights there are 4 screws/bolts and 2 wire clips 2 screws/bolts - on the top screwed into a clip... 2 are screwed to a clip on the bottom behind the light housing
ITR inside |
Re: Headlight Assmbly removal 95 Interga
i need help adjusting the aim of the headlight, do you need to remove the bumper?
the headlight points down too much |
right over the top of the headlights and a little behind it there is a white gear looking thing that you can fit a phillips screwdriver in and either tur it counterclockwise(down, i think) and clockwise(up, i think)........anyway you can go to www.team-integra.net, register and look through the articles and they have a detailed step by step picture article that has to do with this, its very good.......you can go here for alot of the do-it-yourself type stuff
