Old 10-30-2003, 02:17 PM
sats sats is offline
help programming keyless entry 2001 g. prix
I bought an extra remote for my 2001 pontiac grand prix, can anyone helpme program it?
Old 10-30-2003, 02:52 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
All transmitters which are to be recognized by the remote control door lock transmitter (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
Repeat the previous step in order to program each additional transmitter.
Install the MALL PGM fuse into the fuse block.
Operate the functions of each transmitter in order to verify correct system operation.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-09-2003, 06:06 PM
Tam Tam is offline
Re: help programming keyless entry 2001 g. prix
I have tried the steps listed above, and they do not work at all for my 2001 Grand Prix. Upon turning the ignition the first time I get 5 chimes. Opening and closing the door gives me 5 chimes again. I get no synch or confirmation chimes, and of course the remote still doesn't work.
Is there any other procedure for doing this?
Old 09-22-2004, 09:48 AM
BrookeDPete BrookeDPete is offline
I am having the same problem with my 2001 Grand Prix when I am trying to install also.
Old 09-22-2004, 10:04 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Try this. And thank Big-L for it. That's where I got it. But it sure looks the same as above.
http://tacgp.clubgp.com/custom_mods/keyfob/index.html
Old 10-27-2005, 05:48 PM
jimmyv-21's Avatar
jimmyv-21 jimmyv-21 is offline
had the same prob- found out it was wrong remote- what are your numbers on the back
