Old 12-09-2001, 09:42 PM
oedomsa oedomsa is offline
Send a message via ICQ to oedomsa Send a message via AIM to oedomsa Send a message via Yahoo to oedomsa
Exclamation Remote Starting A 5 Speed
Is it possible to Install a remote starter in a car with a 5speed transmission?
Oedomsa
Old 12-10-2001, 08:11 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Assuming you mean Manual, this isn't a problem.... You need to install a safety (lockout) switch that will only allow it to start in neutral --- most kits should have this available.
Old 12-10-2001, 09:45 AM
AEstud's Avatar
AEstud AEstud is offline
Send a message via ICQ to AEstud Send a message via AIM to AEstud
I never knew you could do that.....:bandit:
Old 12-10-2001, 09:57 AM
Neither did I
I'll have to look into it and see how to go about getting it to work...thanx for the tip.
Oedomsa
Old 12-14-2001, 03:39 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Also, try starting it in neutral withough pushing in the clutch. If it starts there you go. Some older cars do not have to have the clutch pushed in to start.
Old 12-26-2001, 03:01 AM
OisinT's Avatar
OisinT OisinT is offline
Banned
Send a message via AIM to OisinT
I want one of dem
Old 12-26-2001, 03:13 AM
dropedlex1 dropedlex1 is offline
Send a message via AIM to dropedlex1
My truck has a
clutch start canel button, its an 87 4runner, you just need to trigger it off, and make sure not to leave your car in gear, youll mess shit up if you try and start it in gear, Duhh
Old 12-27-2001, 03:07 PM
ales's Avatar
ales ales is offline
Forza Schumacher
You guys on the wrong side of the Pool are weird! j/k
I've never seen a car that can't be started without clutch being depressed...
Old 12-31-2001, 02:24 AM
MaxBoost1990 MaxBoost1990 is offline
Send a message via AIM to MaxBoost1990 Send a message via Yahoo to MaxBoost1990
Most of myt 5-speeds could be started w/out clutch depression... Then again, most were Turbo dodges. But my stang, my Stealth, and my RX-7 that I had could all be started w/out clutch depression.. also, this is easily overridden.
Max
"Why is it every domestic thinks they have a schlong bigger than a flagpole?"
Old 01-17-2002, 09:55 AM
Tireburner's Avatar
Tireburner Tireburner is offline
Re: Remote Starting A 5 Speed
Clifford makes a remote start for manual transmissions. You must have the vehicle key started. Then remote start the vehicle, remove the key, exit the vehicle, close the doors and arm the alarm. At this point the car shuts down. You may remote start the vehicle next time you need to provided a door has never come open. This prevents the vehicle from possibly being put in gear.
Old 01-22-2002, 01:18 PM
i_rebel i_rebel is offline
Banned
Send a message via AIM to i_rebel
Interesting . . .
I installed an alarm system with remote start on my car (manual) . . .
I got around the clutch issue by permanently connecting the two wires that would be connected upon depressing the clutch . . . now i don't ever have to step on the clutch to start the car.
The alarm packaging explicitly said: "Not to be used on vehicles with standard transmission" . . . but I just thought that was because of bone-heads that keep their car in gear after shutting it off (what's that about anyway?) . . .
Long story short . . . the remote start won't work . . . the car comes on as if i have put the key in and turned it to the "II" position on the ignition . . . the guages come to life . . . but that's it. It was such a pain in the ass installing the damned thing that I refuse to take it out . . .
Old 01-22-2002, 01:41 PM
Tireburner's Avatar
Originally posted by i_rebel
Interesting . . .
What year, make model vehicle? What remote start? I can probably help get you through it.
Old 01-22-2002, 01:45 PM
Banned
1993 Infiniti G20
Crimestopper CS2005 Alarm
Old 01-22-2002, 01:54 PM
Tireburner's Avatar
Here's the wiring spec's on your car. My thought is that you have hit the second starter wire as your crank wire, but all it does it hit the fuel injection enrichment for start. Both starter wires have to be hit for it to crank and start.
This may not line up right on this page, but here goes...
12V|white |+ |ign. harness |
| STARTER|black/white |+ |ign. harness |
| SECOND STARTER|black/yellow |+ |ign. harness |
| IGNITION|black/red |+ |ign. harness |
| ACCESSORY|white/blue |+ |ign. harness |
| POWER LOCK|orange/black |- |heavy harness in |
| POWER UNLOCK|orange/blue |- |drivers kick panel |
| PARKING LIGHTS +|red/blue | |at switch |
| HEADLIGHTS|red/yellow, red/blue|+ |at switch |
| DOOR TRIGGER|red/white |- |theft warn mod. *1 |
| TRUNK/HATCH PIN|red/blue |- |theft warn mod. *1 |
| HOOD PIN|yellow/black |- |theft warn mod. *1 |
|TRNK/HTCH RELEASE|orange or lt. green |+ |D.K.P./at switch |
| FCTRY ALARM ARM|lt. green/red |- |theft warn mod. *1 |
|FCTRY ALRM DISARM|green/yellow |- |theft warn mod. *1 |
| TACHOMETER|blue/black | |ECC rt. of accelerator |
| BRAKE WIRE|red/green |+ |at brake switch |
| HORN TRIGGER|green/blue |- |theft warn mod. *1 |
| WIPERS|lt. green/red |- |wiper switch |
| LF WINDOW UP/DN|blue, green |+ |in driver's door |
| RF WINDOW UP/DN|red/white, red/black|+ |driver's kick panel |
| LR WINDOW UP/DN|green/blk, green/wht|+ |driver's kick panel |
| RR WINDOW UP/DN|green/blk, green/wht|+ |driver's kick panel |
NOTES:
*1 Theft Warning Module located under dash by steering column
Cool! It worked!
Old 01-22-2002, 02:06 PM
Banned
Hey . . . thanks for that!
That sounds about right . . . cause for some reason it was recommended to me that I only use one starter wire (??). Somebody told me something like that was all we needed on these cars or something like that . . .
Also . . . what is the exact location of that door lock wire? that's another thing I had a problem with.
