Old 10-30-2003, 01:28 AM
Bryan_831's Avatar
Bryan_831 Bryan_831 is offline
Send a message via AIM to Bryan_831 Send a message via Yahoo to Bryan_831
Exclamation Enamel Paint Help Required!
When using Model Masters Enamel paint for brushpainting, must i thin the paint before i brush it on, or can i just stir the paint and use it?
If i must thin the paint, what ratio do i thin it?
Much help would be appreciated!
Special Thanks to Desi Gangsta for the great Avatar
Current Project
Porsche 911 (996) Carrera with Putty Mods
Next Project
Nissan Skyline R34 in White, with SAS C-West Hood
"Some people look good from far.
On closer inspection, they are far from good."
Old 10-30-2003, 07:05 AM
freakray freakray is offline
AF Modelrater
If the paint is on the thick side then I would recommend thinning it, since no 2 bottles of paint are the same I don't know what ratio you would want to thin it.
I would however suggest you thin it so the paint is about the consistency of cooking oil, this will allow better paint flow and help eliminate brush marks.
BTW, make sure to use the correct thinners for the type of paint.
AF User Guidelines
Old 10-30-2003, 03:03 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
For the most part you can use the paint right out of the bottle on a brush. Testors has a problem with their primary colors though, like red, green and yellow, as those for some reason are really thick. However, Model Masters seems to be a little more consistant, so you shouldn't have a problem. If you're unsure, paint a little onto a peice of scrap (like old sprue) and see how well it flows. If you don't like it and think its too thick, thin it, if not, no sweat.
Old 10-30-2003, 06:23 PM
jgmodelcars's Avatar
jgmodelcars jgmodelcars is offline
Send a message via AIM to jgmodelcars
I've never had to thin model master, i've only had to thin testors once, so pretty much you can just use paints straight out of the bottle for brushpainting! Hope this helps!!
My real name is Justin don't be afraid to use it.
Old 10-30-2003, 11:39 PM
Bryan_831's Avatar
Re: Enamel Paint Help Required!
OK, the paint is Model Masters Enamel paint Chrome Silver, and there are brush marks when i paint a part. Should i thin it?
Current Project
Next Project
Old 10-30-2003, 11:49 PM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
Re: Re: Enamel Paint Help Required!
Just put more layers, the brush strokes might get covered up.
-Henry-
