Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-29-2003, 11:18 PM
XBAJBUSX XBAJBUSX is offline
1992 Grand marquis help me
hi i just bougth 1992 g/marquis the car is fully loaded and i like it
but it has the keyless entry on the door how can i program that or get a code for it ,and one more think some times the car leans on the driver side in rear any suggestions the car has air suspension and after a while of driving they even out but not all way ,
thank you 4 reading
Old 10-30-2003, 09:10 AM
jhmoron jhmoron is offline
If you got all of the original paperwork, there should be a laminated card with the Keyless Entry code printed on it. If not, try looking on the bottom of the trunk lid around the latching mechanism. On my '93 GM there is a small sticker that has the code on it. As a last resort you could go to a Lincoln Mercury or Ford dealer and give them the VIN number and they can get it for you that way.
I don't have the air suspension on my Grand Marquis so all I can tell you is that it sounds like you have a small leak either in the air bladder or one of the air hoses.
Hope this helps.
Old 11-09-2003, 11:55 PM
MarquisGT MarquisGT is offline
On most of the Grand Marquis I have seen the factory code is on the underside of the hood. Open the hood and look up and you should find the 4 digit number. This is the fixed code that can never be changed. The computer allows you to set a second code that can be changed whenever you want.
Old 12-10-2003, 10:42 AM
ihatemycar ihatemycar is offline
You have a 92 Marquis? The only hope you have is if someone totals your car. Sorry if I'm a bit bitter...I made a post describing my car in this forum.
Old 12-11-2003, 03:16 PM
clydes270 clydes270 is offline
Registered User
Send a message via AIM to clydes270
Re: 1992 Grand marquis help me
Like others said, the label is on the truck underside. Or, on control module.
5 digit code. Here are the button layouts.
1/2 3/4 5/6 7/8 9/0 (Having same numbers on one button does look silly)
Enter code.
Press 1/2 to unlock drivers door.
Press 3/4 to unlock passengers door.
Press 5/6 to unlock the trunk.
Press 7/8 9/0 together to lock all doors.
To set alternate code. Enter code, then press 1/2.
Within 10 seconds, enter new code. Press 7/8 9/10 together, when complete.
Try new code. Buttons for drivers, passenger, truck, and lock are the same.
I used to use alternate code, but don’t anymore. I’m always disconnecting the battery, when I work on electrical stuff.
Air suspension always levels, OFF or ON. You have a leak. The most severe problem arises, when car is jacked without turning the override switch in the truck OFF. Mainly up on a lift. Here the suspension lets out a lot of air, thinking it is too high. When car is lowered, the pump cannot lift the car. It looks like a low rider.
There is a trick to recover from this without harm, but it entails starting the car, jacking back up quickly, then lowering slowly allowing the pump to recover. Due at own risk.
Most cars suck, when everything starts to fail. If it weren't for my first '83 Thunderbird w/ EECII computer, I would have not learned about cars. But, as I grow older, yea they suck.
