Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 10-29-2003, 09:55 PM
Scbaspan82 Scbaspan82 is offline
Send a message via AIM to Scbaspan82 Send a message via MSN to Scbaspan82 Send a message via Yahoo to Scbaspan82
Unhappy Car smoking, bad methinks
Hey I really need imput on this... I own a 85 fiero SE 2.5 4 banger, all stock, and lately its been idling really high, and while driving its sounding like its getting really strained if that makes sense, like when ill accelrate the car will jerk and then smooth out... but yesterday it was really bad and I got to my friends house and popped the hood and uhh yah smoke came billowing out.... and I coudlnt see any oil getitng burned or any liquid leaking. So any imput would be great lest my car exsplode in a flame and engulf me lol.
Old 12-08-2003, 04:54 PM
erifnuS erifnuS is offline
Re: Car smoking, bad methinks
ummmm, Is it on fire?
Old 12-08-2003, 08:49 PM
coop8267's Avatar
coop8267 coop8267 is offline
sounds like the catalytic converter may be stopped up. my advice is cut it off and put a pipe in its place.
Old 12-08-2003, 09:03 PM
coop8267's Avatar
theres quite a few thing that could be wrong. check the pcv valve. test compression the rings could be shot. cat might be clogged. just to name a few. hope that helps you find the problem. gives you some ideas to start with anyways.
carguyinok's Avatar
carguyinok carguyinok is offline
FYI. The early fiero's had a little thing with the catalytic converter. See they would get a oil leak BUT the oil would never hit the ground. It would fall on the catalytic converter and collect there untill it was a nice grease fire. Fieros & fire go hand in hand. If it wasnt a fire from the cat it was the headlight motor sticking on and catching on fire that was the death of most.
Rules of the game fast,good, cheap pick any 2
fast + good = not cheap
fast +cheap = not good
good + cheap = not fast
Because the water has no speed limits
Old 12-08-2003, 09:04 PM
coop8267's Avatar
if its really hot under there i would bet on clogged cat. if not change out the pcv valve its like 4 bucks
Old 12-09-2003, 12:47 AM
Re: Re: Car smoking, bad methinks
How lost you are....
Old 12-09-2003, 12:49 AM
Sorry.. It WAS'NT Coop that said that!! It was carguyinok
Old 12-09-2003, 08:51 PM
coop8267's Avatar
i've never heard of a headlight motor caching on fire either erifnuS. mine stripped out and it ran for a while before i could unhook it and it never even smoked much less catch on fire.
