Old 10-29-2003, 09:33 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Question Broken off spark plug
Hey all, I'm helping this kid do a mini-me swap, and he just got the head on and did the timing belt and everything, and put in the spark plugs. The car wouldn't start, so he decided to pull the plugs and check them. Well, he tries to pull one out and it breaks off just at the top of the threads. Has this ever happened to any of you guys/gals? Is there any good way of getting this out without pulling the head back off and taking it to a machine shop? Any help would be great!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 10-29-2003, 10:40 PM
pm5 pm5 is offline
The best thing to do would probably be to just get it removed professionally...or i guess u could try to drill a hole in it and clean out the threads with a tap and die. Either way u would have to remove the head to avoid dropping junk into the cylinders. Whenever u change spark plugs its a good idea to use some anti-seize compound on the threads so u can take them out easily later on.
Old 10-30-2003, 07:47 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
They do make kits where you can use a tap and die to re-thread spark plug holes. I used one on a 87 prelude I once had, but my plug wouldn't go in due to screwed threads. I think you may have to take off the head to safely get the plug out, you dont want that ceramic and metal crap getting into the engine.
Old 10-30-2003, 11:24 PM
4GZChatch's Avatar
Re: Broken off spark plug
yeah, i figured that it would require popping the head off, but hoped that there would be some miraculous way of getting around it. Anyway, I told the kid to pull the head, and I have a machine shop that is going to EDM the sucka out of there...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 10-30-2003, 11:49 PM
NJ1989si's Avatar
NJ1989si NJ1989si is offline
thats not that bad, i had the electrode or prong break off during driving(spraying nos) and is inside the cylinder. I have 130 000 miles on my D16A6 and now thinking about swapping it with a B16. I would never ever recomend a dry nos kit to anyone!!
Old 10-31-2003, 07:38 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
take the head off and unscrew the spark plug form the bottom with pliers or something
Team Lonely Drivers
