Old 10-29-2003, 10:05 PM
prankstar prankstar is offline
A/C Orifice Tube location?
can anyone tell me where to find the orifice tube for my A/C. I have a 1994 chevy 1500 with a 350 engine. Thanks
Old 11-01-2003, 12:52 PM
stevemisel stevemisel is offline
Re: A/C Orifice Tube location?
I suspect it's in the same place as my 1990.. Remove the left side (front, of course) turn signal light. Behind it is an AC fitting ... disconnect it. The orifice tube is right there.
My father-in-law and I went *silly* looking for it too.
Make sure you put the new tube in the same way as the old one - it's easy to install backwards.
You should probably put new O-Rings on. Also make sure to replace the dryer each time you have the system "open".
Good luck.
-Steve
Old 11-01-2003, 12:53 PM
Re: Re: A/C Orifice Tube location?
Good luck.
-Steve
Erp, make that the "passenger side" turn signal... :-)
Old 11-02-2003, 01:25 PM
what do you think about the dryer in my situation
yep, I found it. It was in the condenser where the liguid line comes out of it.
Now about that accumulator(dryer) I just bought a new one with a compressor and had it installed. I got my truck back and my A/C worked for a day before all the 134a leaked out. So I take it upon myself to fix it the right way this time. But anyways I took the dryer off and capped it off so it should be alright to reinstall do you think?
Old 11-03-2003, 01:33 PM
Re: what do you think about the dryer in my situation
You're probably alright. The determining factors would be ambient humidity and amount of time the dessicant was exposed.
I'd run through every fitting and put new O-rings on (including the manifold to the compressor) and charge it up again - this time with some dye.
Good luck!
-Steve
Old 03-20-2004, 04:12 PM
ddnn ddnn is offline
can anyone tell me where to find the orifice tube on my 1996 camaro z28
Old 03-20-2004, 06:33 PM
Check out ackits forum. they will help you very quickly and knowledgeable about ac work.
Old 03-22-2004, 07:31 AM
desertmike1 desertmike1 is offline
Orfice tubes on all autos&trucks are located in the "ambient" refrigerant liquid side, between the condensor and the accumulator typically next to a fitting or joint.
Now getting to it could be a differant story.
Old 07-01-2009, 08:54 PM
miverson332's Avatar
miverson332 miverson332 is offline
I have a 94 Suburban 350 with dual air. My orifice tube was on the middle of a line running directly under the battery. I removed the passenger blinker cover and disconnected the line there, but could not see the orifice tube. I then followed that same line back toward the firewall, and directly underneath the battery is a connection and inside was the old nasty orifice tube. Good luck.
Michael Iverson
"Just A Fat Kid With Broken $h!t!"
