Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-29-2003, 08:38 PM
93civic$racer 93civic$racer is offline
Question suspension question?????????
As you can see i have a 93 civic dx and in the near future i plan to completey transform my car into a drag machine and i was wondering would i need to go all out and purchase cambers, strut bars, sway bars.....etc. or would i be alright with just springs and struts??? thanx for the input.
Old 10-29-2003, 10:28 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
Re: suspension question?????????
is it gonna be a track only car?
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 10-29-2003, 11:19 PM
BullShifter's Avatar
Re: Re: suspension question?????????
For drag racing only
1. Tires
2. Springs
3. Shocks
4. Traction bars(if needed)
A sway bar will do NOTHING in a straight line, besides add unwanted weight - racers worst enemy.
Eibach has some nice Drag Launch springs
Old 10-30-2003, 08:23 AM
its gonna be about 90% track and 10% street only because i already have a grocery car so i want this car to be full drag.
Old 10-30-2003, 01:19 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
What you're going to want to do is have a STRONG emphasis on the front suspension. Basically you'll want the get the rear stiffer, but have the front TWICE as stiff to compensate for wheel hop and such. Keep in mind that a setup like this does NOT handle well at all on the street, if you decide to drive fast and whip around corners. This set up will cause your car to have way exadurated understeer, and just won't be well unless you drive it like normal. On the drag strip it can give an advantage.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 11-03-2003, 05:06 AM
Sulsa Sulsa is offline
Just a quick note. When ppl say "track" they generally mean racing on a shaped track(not straight) in which turn radius, and cornering performance are an issue. When you say "Drag Only" in reference to your car, we assume this to mean you will only drive it in a straight line for about a quarter mile at a time.
94 Integra LS
Engine is in the car!
Installed parts
GSR block/head, ARP head studs, eagle rods, Endyn pistons/rings, King bearings, REV stainless valves, Portlfow springs &Tit. retainers, BBK 70mm Throttle body, RC 310cc Injectors, Aerospeed plug wires, generic 2.75" CAI, Civic SI crank pulley, 130amp alternator, Hondata S300 in P72 ECU
01 GSR shocks/springs, 17" Enkei Zenkei's, Homemade Black ABS trunk floor
Mods: Removed AC system, routed Coolant Outside Intake Mani
Old 11-03-2003, 08:15 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
In theory you will want something height adjustable, being able to tune the suspensions pitch.
A coilover setup will help you tune your car to prevent dive and squat.
In this case, you don't need anything wild, but, I would recommend something like the Koni Yellow, Skunk2 sleeve, or CG sleeve for this.
With a skunk2 camber kit up front, Ingalls, shim or SPC kit in the rear.
Caster you probably won't mess with.
Pick your rates, and order them. You will want a stiff setup.
500F/400R or higher.
Consider, hard bushings up front as well.
M.Sanew - AutomotiveArticles.com
