Old 10-29-2003, 08:03 PM
90cIvIcSiR 90cIvIcSiR is offline
Send a message via AIM to 90cIvIcSiR
Heater not workin....frickin cold!!
How do I fix it....it blows air, but never heats up??? Please help as I am slowly freezin' to death.. . . . .
Old 10-29-2003, 08:11 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Heater not workin....frickin cold!!
Check to see if the air duct flap that allows cold/hot air is working, flip it back and forth, see if you hear a noise of it moving.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 10-29-2003, 08:23 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
I had a 86 4Runner with the same problem last year so I bought a radiator flush from Checker Auto. Then I reversed the flow of the fluid going to the radiator core because they can get pluged up. The way to do that is to switch the 2 coolant hoses going inot the core by the fire wall. If all goes well you should notice in like an hour or 2 within doing the switch. then run another flush through it. I would drive it around like that for a couple of days. And It won't hurt the core in anyway. If that doesn't work then it could be your radiator core is gone bad.
Check out my car here My 91 Hatch
Old 10-29-2003, 09:31 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Your thermostat could be stuck open, if that happened, it would take a LONG time for it to get hot air.
Old 10-30-2003, 08:58 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh it could be your thermostat or low coolant.
Old 10-30-2003, 09:14 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I thought we were talking about the heater/AC inside his car, guys... not his engine cooling system.
What exactly does the thermostat or antifreeze have to do with the heater?
Honda Enthusiast
Old 10-30-2003, 09:28 AM
mellowboy's Avatar
Killa Crx - how do you think heater works? Just answer that for me
Old 10-30-2003, 10:21 AM
Killa_CRX's Avatar
When Civics Attack!
Re: Re: Heater not workin....frickin cold!!
And that's the question I asked for you to answer. I don't know yet.. I haven't torn that part of my car apart yet, and never had to work on the heater before.... therefore please explain so those of us who don't know may understand how it works better and be able to fix it next time.
I just never have really thought about it or questioned it before.
Honda Enthusiast
Old 10-30-2003, 11:42 AM
mellowboy's Avatar
Re: Re: Re: Heater not workin....frickin cold!!
Well if the heater is not blowin heat. It could be a bad thermostat or low coolant. Those are teh two main reasons
Old 10-30-2003, 12:44 PM
havnfun328 havnfun328 is offline
I think there's a valve on the supply line to the heater core. Check the valve and the pushrod to the valve.
Old 10-30-2003, 03:09 PM
You put fluid in your radiator. it goes into the head of the motor circulating throughout the whole motor and then out of the block and into the heater core back out of the heater core then back to the radiator. The heat from the motor makes the coolant hot then it goes to the heater core making your car oh so warm in the winter ( if it works ) and thats the just of it, I probably left out something but that is it for the most part. If your thermostat is stuck open the block never heats and that would mean the core doesn't get hot enough coolan. Almost all thermostats that I know of when they fail they fail in the open position, so coolant can flow making sure the car won't overheat. If I forgot anything LMK
Old 10-30-2003, 03:16 PM
Killa_CRX's Avatar
When Civics Attack!
Awesome... Thanks
Honda Enthusiast
Old 10-30-2003, 10:00 PM
Awesome... Thanks
no problem
