Old 10-29-2003, 07:54 PM
pm5 pm5 is offline
Question MPFI distributor wiring
To peeps that have done a MPFI swap: how did u hook up ur distributor wiring? I had to swap the distributor connector to add the cylinder sensor wiring and i only had the distributor side of the Si harness, so i just hooked up the distributor wires by matching the colors to the DX harness the best i could. Heres how i made the connections:
Yel/Grn from Si to Tan/Grn on DX
Tan to Orange
Tan/Blu to Org/Blu
Wht to Wht
Wht/Blu to Wht/Blu
The car still wont start. Is it possible i hooked the wires up wrong? If so, did i damage anything (igniter, sensor, etc)?
Old 10-29-2003, 09:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: MPFI distributor wiring
you still need to run 2 more wires from ecu. should be 7 wires total. check this out:
http://www.4thgenerationcivic.com/ho...conversion.htm
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-29-2003, 10:32 PM
pm5 pm5 is offline
Yeah those are the cylinder sensor wires...there was a Blu/Yel and a Blue wire on the distributor side of the connector, i ran those to the ECU with shielded wire. But no one talks about the other 5 that were already there so i wasnt all that sure about how to hook them up. Did i do it correctly?
BTW, i love ur website
Old 10-30-2003, 12:00 AM
gsf1200m gsf1200m is offline
It sounds like you did the rest of the wires right. All it is is mathching up the colors thats why nobody says anythign about it. I think the tan wires you have used to be orange, at least thats how mine was.
