Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-09-2001, 05:32 PM
guiltyofdeicide guiltyofdeicide is offline
buzzing..rattling..roaring kinda noise
the noise i attempted to describe in my title occurs when my car (95 GSR, ~110000mi) is revved in the 3k-3800rpm range or so, regardless of the gear. I seem to remember reading something about something like this earlier..exhaust manifold cover or something. Anyways, the point is, i don't remember. If someone could point me in the right direction, i'd appreciate it.
Old 12-09-2001, 07:28 PM
OisinT's Avatar
OisinT OisinT is offline
Banned
Send a message via AIM to OisinT
my heat shield above my CAT was rattleing against the cat and exhaust.. and I could feel it in my shifter too...
I simply cut the edge off my heat shield... problem solved!
Old 12-09-2001, 10:34 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
Ditto. Just remember not to park in any tall grass if you take off the heat shield.. that or anything else flammable that can touch your cat (while it's hot) will catch fire!!
Old 12-10-2001, 10:54 PM
92 Teg-B18A's Avatar
92 Teg-B18A 92 Teg-B18A is offline
if it is the heat shield you could try taking it to a muffler shop and get them to tack weld it down. Might be easier than having to worry about things under your car catching on fire!
92 Acura Integra RS
B18A is the bizzam
PH refugee
AF Nordic Crew #004
Warning: The Surgeon General says it's OK to smoke V-8's.
Old 12-11-2001, 12:26 PM
JD@af's Avatar
Missing in action
That’s true. But I have heard tales (actual true tales, by the way) of heat shields being welded, only to find that the noise persisted. The heat shields were then removed. Just something to keep in mind…
Old 01-25-2002, 07:03 AM
Sandman Sandman is offline
I had the same problem for 2 different problems one was a bad A pipe the other was the heat sheild. Right between 3K and 3.5K you would hear that annoying rattling. I went through 3 A pipes while under warranty and as soon as the warranty was through( luckily I had a 7 year warranty), I got a full stainless exhaust and headers from Comptech so I wouldn't have those problems again.
