Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-29-2003, 01:27 AM
95civicTurboed 95civicTurboed is offline
Exclamation Turbonetics Turbo Q!
Hi im building a 2000 Civic SI coupe. Has the Stock B16A2 engine with nothing done to the interals. This kit runs 8 psi base i guess and it can be turned up? But i was wondering how far i can safely turn it up so that i dont throw a rod or what not. Also i was wondering about comments about the turbonetics turbo what people think and what problems there are. Thanks.
Turbo Kit - Si B16A2 1.6L DOHC - 8psi - Kit includes Custom T3/T4 Hybrid Turbocharger, Intercooler System, Exhaust Manifold, Fuel/Timing Management System, External Wastegate Assembly, Fuel Injectors, Mandrel-Bent Downpipe, Intake System, Air Filter and Hardware/Fittings - *90 horse power increase over stock $3,545.73 - EA
http://www.nopionline.com/index.cfm?...grade&vaffid=0
Old 10-30-2003, 08:30 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Turbonetics Turbo Q!
dont not boost past 8psi they set it there for a reason, it will be unsafe to boost it over 8psi you can risk blowing you motor.. so keep it low . i think with a head gasket you cna run9-10psi saftly..
1
Shift_BOOST
97 s14
Old 10-31-2003, 01:11 AM
hondaracer hondaracer is offline
Re: Re: Turbonetics Turbo Q!
Yes I've read about that package and its set at 8-9psi for that reason. Do not run any higher unless you want a blown head gasket, which could lead your car to losing a lot of oil and than having the engine freeze. which than you'll have to take apart the whole block and take out everything. People are so interested in running such high boost but 8-9psi will give you a nice feel and power increase over stock. Plus also running higher boost on top of those non-forged pistons and rings..... not the best of ideas. Go all motor!!!! you'll like it! I do.
For Sale: Turbonetics Spec V turbo kit 04-05 $3400 TeamTurbo Sentra | 200SX (USDM FWD) 2 08-05-2009 12:54 PM
FS: Turbonetics Spec V turbo kit 04-05!! $3400 TeamTurbo Sentra | 200SX (USDM FWD) 0 08-03-2009 03:51 PM
Buying B-Series Turbonetics Turbo Kit krnsamiam N2O | Turbo | Superchargers 15 10-15-2005 11:46 PM
Turbonetics Turbo kit anyone??? CougarSVT SC300/SC400/SC430/Soarer 0 12-15-2003 02:24 PM
