Old 10-28-2003, 10:48 PM
WhiteCavaliac WhiteCavaliac is offline
Send a message via AIM to WhiteCavaliac Send a message via Yahoo to WhiteCavaliac
Question How to get factory 6x9 out?!
How can I get the 6x9 speakers out without tearing up the carpet?
Old 10-29-2003, 03:35 PM
Mike K Mike K is offline
Send a message via AIM to Mike K
Here is a link that shows you how:
http://www.carstereohelp.com/stereor...r2RDeckSpk.htm
Old 11-02-2003, 05:54 PM
s8kimo's Avatar
s8kimo s8kimo is offline
Send a message via AIM to s8kimo Send a message via MSN to s8kimo Send a message via Yahoo to s8kimo
rear deck removal
not very good instructions. but just be very easy with it as always. i wan't able to pull back dash out all the way. i was however, able to lift it up just high enough to take old out and put new in. good luck
Old 03-05-2004, 11:31 PM
conanthedestroyer conanthedestroyer is offline
Re: How to get factory 6x9 out?!
the back speakers should be accessed through the trunk
Old 03-07-2004, 10:06 AM
04_CaV!! 04_CaV!! is offline
depending on the year of the cavy. If its a 94 and older they are accessed by the way of the trunk and are held in with a simple spring clip. If it's a 95 to present you will need to drop your rear seat and pull off some plastic panels in order to access the speaker.
YOU WANT IT WHEN?
Old 03-09-2004, 01:43 PM
SilvrCavQt's Avatar
SilvrCavQt SilvrCavQt is offline
You can grip the plactic pieces of the back dash and just rip them out, there held on by clips so dont be worried about breaking them. Once you get the two off the back will slide out and then you have all the access you need. Start taking the plastic piece by the top of the doors first.
2000 Cavalier 2.2L
http://www.geocities.com/silvrcavqt/
Old 03-09-2004, 01:48 PM
SilvrCavQt's Avatar
Exclamation Re: How to get factory 6x9 out?!
I mean they wont break.
2000 Cavalier 2.2L
