Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-28-2003, 08:28 PM
97HCiViC 97HCiViC is offline
Turbo CRVTEC Question
I was planning on building a CRVTEC motor for my car. I want to make it F/I so i was wondering what is the ideal compression ratio for the motor?..? It's a b20z block with a b16a or b if i can find one head. Also i was wondering if there are any special parts i need and such. Also any info if anybody has built one for turbo. Thanks! -97HCiViC
Old 10-29-2003, 04:26 PM
Jeff C's Avatar
Jeff C Jeff C is offline
How far are you wanting to take it? How much you willing to spend?
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-29-2003, 08:39 PM
I have about $8,000-$9,000 dollars to spend and i want to get it to at least high twelves or low thirteens
Old 10-29-2003, 09:23 PM
disbboi disbboi is offline
a stock crvtec and 10 psi should get you too your goal
and if you want to build up your enigine 9.5.1 cr and maybe sleeves if you wanna go over 15 psi
Old 10-30-2003, 07:54 PM
What ratio should i go if i want to run at 10 psi?..? And also what's a good turbo to use?..?
Old 10-31-2003, 01:12 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Turbo CRVTEC Question
get a big hairy T3/T4 turbo with $9K you can easily get a turbo kit and build up the block to get you into the 13's. I think you're biggest concerns will be forged rods and pistons, resleeving the cylinders and getting the block decked. That should give you a pretty strong block so you can up the boost at the track. I suggest you run somewhere between 9.2:1 - 9.5:1 CR. A lot of other things go into calculating CR, so just try to get it somewhere between those two numbers. That way you aren't a total dog off of boost. However, you can run semi high compression and still have a reliable vehicle as long as it's tuned properly.
Empty Pockets Racing Member #1
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
