Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 10-28-2003, 06:09 PM
bobcat47 bobcat47 is offline
Question 1997 pcv valve replacement
Where can I find the pcv valve on the 3.3 v6 and when
is it recommended for replacemnet?
Old 10-29-2003, 07:42 AM
lewisnc100 lewisnc100 is offline
Re: 1997 pcv valve replacement
The PCV valve is attached to the top right side of the upper intake manifold, don't have a picture handy but if you go buy one and then hold it up to the hoses that go into that side of the manifold you should see the right one fairly easily. I replaced mine at around 95k and it was still clicking back and forth but did have some oil buildup. Make sure you soak the valve with a penetrating oil or WD40 for 15 minutes or so before attempting to loosen the valve. Someone else on another board busted their intake manifold trying to get theirs out. Mine came out very easily and replacement just took a couple of minutes. A new valve should only be around $2.00 at any auto parts store.
Old 10-29-2003, 07:24 PM
hbar hbar is offline
Question
WHAT ARE THE SYMPTOMS OF A BAD PCV VALVE ??
TIA
Bahr
'93XE v6
Old 10-30-2003, 06:48 AM
TIA
Bahr
'93XE v6
Not really sure what all the symptoms are, I think it depends on whether the valve is sticking open or closed or a little of both. I know one of the common symptoms mentioned is that you'll start to see some oil on your air filter.
Old 10-22-2004, 01:25 AM
4x4dillo 4x4dillo is offline
ive had the same problem. i have oil in the air filter and relpaced the pcv valve but i still have oil in the air filter.
