Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 10-28-2003, 06:54 PM   #1
Hooleman
Send a message via AIM to Hooleman
Unhappy Crank no Start
'93 Lumina, Died in flight last night. checked fuel level and spark, crank no start. Tried shooting some "auto-start" (carb cleaner) in the throttle body: It ran smoothly till applying acceleration, where it would drop cylinders and eventually die. I'm thinking it's the fuel pump, but unsure. Could anyone help me with this and if it is the fuel pump, how can I access it? (or do I have to drop the gas tank).
Hooleman is offline   Reply With Quote
Old 10-29-2003, 10:14 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: Crank no Start
If you disconnect the wiring connector at the gas tank (should be a 4 wire conncetor with 2 black wires , 1 purple and 1 gray wire) and probe the gray wire on the car side of the connector with a test light to ground, have someone turn the key on..the test light should light for 2 seconds..after that spin the engine over and the light should stay on the entire time.
If the light comes on then the electical control circuit to the pump is working and most likely the pump is bad.
You will need to remove the tank to access the pump.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 10-29-2003, 05:07 PM   #3
Hooleman
Yep, Droped the tank and found out that the pump was rusted off. Thanks a bunch for your help
