Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-28-2003, 04:28 PM
integraluva integraluva is offline
Send a message via AIM to integraluva
what engine/what turbo
i have a 92 integra ls with a brand new clutch in it. i have $5000 dollars to play with and i definately want to swap in an engine and then turbo the motor. i was thinking some sort of b18 but im not sure. what do you guys think for an engine and then what turbo. If necessary i can extend my budget but i would like to keep it to 5k. thanx guys, any help from knowledgeable people is appreciated.
p.s also what type of horse power could i expect from whatever engine and turbo u reccomend
Old 10-29-2003, 12:33 PM
kpsycho's Avatar
kpsycho kpsycho is offline
uh if its a 92 teg ls uh you should have a b18 in there already so just go for a turbo setup dont worry about swapping
Old 10-29-2003, 01:59 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
They arent as strong as the b18b's and you probly have a good amount of miles on it right? You could fortify the internals or swap, and then turbo it. Did you want an engine with VTEC.
Old 10-29-2003, 06:52 PM
honestly, i want whatevas the best
Old 10-29-2003, 11:59 PM
Spectre927's Avatar
the best is expensive. Just fortify you're engine with strong internals. Rods, pistons, bolts, sleeves, etc. etc.
Old 10-30-2003, 11:57 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
cheapest way would be to swap a b18b1 w/ lower miles, and turbo that.
u'd be into the 13's w/ that set-up alone (w/ stock internals).
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 10-31-2003, 02:21 AM
is the b18b1 the same engine in a gsr?
Old 10-31-2003, 02:33 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
no, the b18b is not the same as a gsr... it is rated at 142 hp and like 127 trq i believe. the gsr is a good bit more than that and quite a bit more expensive as well. it is said that a b18b can handle as much as 12 psi of boost on stock internals, to put one in your 92 though I am pretty sure you are going to be playing with the obd computer jazz... (I think yours is obd0, I know the b18b is at least obd1, the newest may even be obd2 but I am not sure of that)
LS1 RX-7 Zoom Zoom
Old 10-31-2003, 04:26 AM
Re: what engine/what turbo
the 94-96 integra ls rocked the b18b1 that came w/ 142/127 (obdI). the 97-up came w/ 140/127 (switched to obdII, but was still the b18b1).
the motor CAN take up to 12 PSI on stock internals, but as always, the more u build the motor, the safer u'll be.
2003 Infiniti G35
Old 12-08-2003, 12:59 AM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
Re: Re: what engine/what turbo
Almost. The 96 ls is the first to sport the OBDII system
DoubleTap
Old 12-08-2003, 05:52 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
the only diffrence between the b18b of 91-93 integras vs the others is, the fuel rail is bigger, along with the intake manifold, and the throttle body. Block stays the same. head is diffrent too.
94-96 integras come obd 1. that means thorottle body on 94-96 is diffrent. 98+ have obd 2. that means 2 o2 sensors, even more sensore, same parts other than the throttle body, and the intake manifold has more sensores as well.
94 INTEGRA NEVER LOOKED SO GOOD ^^
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
