Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-28-2003, 11:47 AM
TanyaT TanyaT is offline
Exclamation Engine Whistle Ram 1500 2001 4X4
I live in the NWT and only in the winter does my truck make this slow whistle sound. I warm it up for at least 15 minutes before drive, I bought a winter front...and still I get greeted with this whistle. It doesn't happen at high speeds. What can I do??
Old 02-24-2004, 08:22 PM
94dodge 94dodge is offline
Send a message via MSN to 94dodge
Re: Engine Whistle Ram 1500 2001 4X4
its just air being sucked into the intake
Old 02-29-2004, 11:23 PM
Anaudiophile Anaudiophile is offline
Check and make sure the air intake snorkel is properly fastened to the throttle body. They will whistle if it isn't fully seated on the fiber gasket on top of the throttle body.
You may also require a good throttle body cleaning. Excessive carbon build up around the throttle blade and AIS passage can create a whistle also.
Old 03-05-2004, 05:12 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
My truck did that when it was really cold out. I think it was just the idler or one of the other pulleys on the belt path that did that from the bitter cold. It would stop doing that once you got going and everything warmed up though...
Old 03-05-2004, 11:35 PM
pind pind is offline
I noticed that with mine too, and although i am running a diesel, there was something other than a turbo whistle when cold. Turns out there was a flow restrictor in the heater line, which produces a whistling sound in colder temps. go figure. I don;t get it. But, thats ok, great trucks, wouldn't have any other. I live in the Yukon, so we run in close to the same conditions.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
Mild heat from 95 Ram 1500 SLT 4x4 5.9L dlbaugh Ram Pickup | Ram SRT10 2 12-30-2006 09:59 PM
97 ram 1500 360 4x4 tuesd97 Ram Pickup | Ram SRT10 6 12-16-2006 04:10 PM
