Old 10-28-2003, 10:31 AM
fa442fa fa442fa is offline
I need to know what it is ......
Yesterday I hit a rock and it bounced up and hit something under the drivers side of the van. Just behind the drivers seat. The part it hit is now hanging down. It looks like a small piston of some sort. It black with a metal rod coming out of it with a black rubber piece on the end. I looked under and see where it hooks in the underside and I'm able to push the end with the rubber piece back in the bracket. But what I need to know is what is it and I'm I in any danger if this thing keeps poping out.. Help please.
Old 10-28-2003, 07:50 PM
timd timd is offline
What year is your van?
Old 10-28-2003, 08:26 PM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
Sounds to me like it's the Evap Leak Detection Pump Solenoid... at my local dealer it's a $135.00 part...
What is it..
There is a line that leaves the gasoline cap that runs to it. It collects all the fumes in it and there is a solenoid under your hood located in the front left side that at about 45 MPH tell it to release the fumes to the engine and burn them up (Use them as fuel)
How do I know this look up my post:
http://www.automotiveforums.com/vbul...66#post1129866
Your CE light may come on with the Diagnostic Trouble Code FP1495.
That is NOT a Major issue you can continue to drive your van like this as it will not harm your catalytic or anything else for that matter. (according to the error I had)
Again this is just my guess as I had that issue on my other thread and that is where the canister is located on my 97 GC
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
i need to know what amp i need iammykehawk Camaro Discussions 10 06-20-2005 10:50 PM
need to know what kind of paint my friend would need to use on his 90 hb curtis_95hb Automotive News Desk 1 06-12-2004 11:58 AM
Need to know what color is that ? Vric Car Modeling 16 04-03-2003 04:59 PM
Need to know what car this is. MR2_Lancer General Discussion 4 08-12-2002 10:23 AM
