Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 10-27-2003, 08:47 PM   #1
gdavid
1991 pathfinder fuel problem
1991 pathfinder wrecked with front end damage. started fine before body repair (welded fender parts) battery was disconnected at time of repairs. Now will turn over and will run if gas sprayed directly into intake, but otherwise will not run on it's own. No codes in ECU. Fuel pressure at fuel rail is 50 lbs/psi. Does anyone have any suggestions???
gdavid is offline   Reply With Quote
Old 10-28-2003, 01:22 AM   #2
88pathoffroad
Send a message via ICQ to 88pathoffroad Send a message via AIM to 88pathoffroad Send a message via Yahoo to 88pathoffroad
Test the injectors all separately? Test for spark on all plug leads? The ignition coil transistor may have been fried...that's the little square deal next to the coil, wired to it.
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc
Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
88pathoffroad is offline   Reply With Quote
Old 10-28-2003, 08:22 PM   #3
gdavid
Re: 1991 pathfinder fuel problem
Hope I am doing this right. This is the first time that I have used this site. I checked the coil and readings are fine. I have spark to all all plug leads. I am going to check the injectors tomorrow. When I use a spray bottle and spray fuel directly into the intake pipe - it will run fine - idles correctly and everything. Could there still be a problem with injectors??? I was also wondering about the fuel pressure regulator? Does anyone have any ideas about this? Thanks for the help!
help please. 84 yota fuel problems CBRrider Pick-Up 8 12-01-2009 09:16 PM
95 Aurora Fuel Problem? ffinoh Aurora 3 11-18-2009 03:43 PM
1991 probe fuel problem engine 2.0 juggie#1 Probe 0 05-19-2006 08:19 PM
1991 probe fuel problem juggie#1 Probe 0 01-27-2006 11:59 PM
1991 gmc fuel problems iggycat1 Sierra 1 04-14-2004 01:51 AM
