Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-27-2003, 05:13 PM
ShoofIsLudin ShoofIsLudin is offline
Question H22 Swap, H23 ECU, are there ANY problems???????
Whats up guys, this is my 1st post. I'm having a JDM H22 put in my H23 Prelude. I'm keeping the h23 tranny with hopes of a turbo or supercharger later, but I don't have the money to get the p13 Ecu for the H22, will the p14 ecu for the H23 still run my motor. I kno i'm not going to have Vtec, and its gonna be slower, but are there any main problems with this combination? Does anybody out there have the same setup as me with any advice....please HELP!!!! OBD 1, p14 ECU, H23 Tranny, and JDM H22 motor
Old 10-29-2003, 12:38 AM
strodda strodda is offline
sorry i cant help, just wondering though... how do you have money for an entire engine, but you cant afford a $100 ecu?
Old 10-30-2003, 03:05 PM
I spent my money on the engine + Swap, and i forgot about the ECU until it was too late...i'm an idiot...i know
If anyone would happen to know about this combo please inform me bekuz i'm clue less about it bekuz i haven't found anybody with it...
JDM H22A1, H23 Tranny, H23 Ecu...
Old 11-09-2003, 10:31 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Yes it will work, however you will not be able to use the VTEC until you get the right ECU, you will also have to do some modifications to the distrubutor.. I can't tell you exactly what, but may have an answer within the next day or so as my partner just did that same swap and we are trying to get it running right.. He had the H23 Distributor on the H22 and it worked fine, but when he went to put on the H22 distibutor it did not work... ECU? Or some rewiring of the distributor? Basically Internal to External coil issues. Don't know yet but will post as soon as we find out.
Peace
~J
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 11-23-2003, 12:35 AM
lukeman70 lukeman70 is offline
Re: H22 Swap, H23 ECU, are there ANY problems???????
You can use the h23 ecu&activate the vtech system with a rpm activated switch like the one msd sells.
Old 11-23-2003, 10:15 AM
Re: Re: H22 Swap, H23 ECU, are there ANY problems???????
Sounds easy and generally would work, but the two Engines are spec'd differently and should be ran with their respective ECU.
~J
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 11-24-2003, 01:58 AM
prelude97 prelude97 is offline
Cool H23 Block H22 Vtech Head
Hey man u made a mistake by doing the whole engine swap. What u should of done is kept the h23 block(more tourqe then H22) and put on the h22 vtech head. fo a total of 3000 dollars u would of head a fully rebuilt head Port and polish, new camshafts etc. After u would of done that u would like have 300 horsepower.
My brother is gona do a project next summer that way like a 93-96 prelude with h23 block and h22 fully rebuilt head.
But about the computer i think there is places where they reprogram them to where the vtech will turn on. check with some import shops or maybe a honda dealers shop.
Old 11-24-2003, 06:20 AM
Re: H23 Block H22 Vtech Head
vtech? You made a mistake by calling it vtech! It's VTEC. If your gonna give advice have a clue as to what advice you are giving.
As long as your using the H22 ECU (P13) (wired correctly) your VTEC will engage without the assistance of other computer hardware.
And the swap, I recommend a full H22 over a "Frankenstien" H22 head on an H23 block anyday.
Here are a couple places that you should check for ECU reprgramming and upgrade.
www.jetchip.com
www.hondata.com
Peace
~J
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 11-27-2003, 12:14 AM
wagsaccordsir why u gota be and asshole. first of all he doesnt have a h22 ecu hes got the h23 ecu. and the reason i said use the h23 block is cause i know guys that did the h23 and h22 and that thing had more power more tourqe then h22 full swap. so thats my advice he doesnt have to do that. and plus it would have been cheaper for 3500 he would have h22 vtec head fully rebuilt.
Old 11-27-2003, 06:35 AM
Asshole? I guess your perception is your reality and if thats what you wish to percive then by all means; I'm an asshole!
If would have read my post a little more clearly I never stated that he had actually had an H22 ECU, I know he has the H23 ECU. What I said was; "As long as your using the H22 ECU (P13) (wired correctly) your VTEC will engage without the assistance of other computer hardware."
"And the swap, I recommend a full H22 over a "Frankenstien" H22 head on an H23 block" You see the keyword in there? RECOMMEND! Don't get it misconstrued. Just like you offered your advice, I offered mine.
My bitter feeling, is that too many people are overwhelmed with doing the "swap" these days, and don't acknowledge the absolute cost in such. It isn't about putting this or that engine in your car to be cool, its about whatever your going to do, atleast do it right the first time and avoid half-assing such an investment. How can one afford the swap, but can't annie up the extra 100 bucks for the right ECU?
Your built up "Frankenstien" theory? All I can say is; "To each his own".
Peace
~J (The AF Asshole!)
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 11-27-2003, 02:16 PM
Well hey man im sticking with the h23 and h22 head. no one has to do what i say (right). so all i said is that it would have been better but all u guys think that the full h22 gets u more power. i dont care if u all think that the h23 h22 are not good together i like it so its my problem.
Old 11-28-2003, 01:23 PM
Hey guys...thanx for all ur help and all, but if the ECU was ONLY $100 i'd have it...if you can get 1 for that cheap...let me know and i'll hop on that...as far as the "frankenstein" stuff, I spun a rod, and something about a piston. the h23 had 100K+ miles on it, and there was a leak in the block, and i didn't want to rebuild that POS. My car is running fine, and everything is hooked up for vtec, i just have to plug in a P13 ECU and i'll be good to go. I plan on going turbo real soon, and thats why i'm not gonna shell out 3bills for an ECU right now. BTW, does anyone know of a short shift for 4th gen LUdes other than the stupid ass adapter...ACTUAL short shifter? My car has more torque than it did b4, until it hits 5k RPMs...then it gets depressing bekuz its not like that when theres VTEC....I can't wait!!
Old 11-28-2003, 01:58 PM
I know its not a $100 bucks but its relatively cheap
http://cgi.ebay.com/ebaymotors/ws/eB...category=33596
Peace
~J
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 11-29-2003, 10:49 AM
Peace
~J
The winning bid on that auction was $455. I appreciate your help and effort wagsaccordsir, BTW did u ever work out that distributor problem that ur partner was having?
Old 11-29-2003, 11:29 AM
Damn that was insane, whoever paid that must have been desperate..
Sorry!
Here are some Buy it now's.
http://mpf-search.ebay.com/search/s...96&BasicSearch=
My friend... That's a whole nother story!! LOL
His problem is because he's using the wrong ECU and he thinks both will work, the wiring is different between the two ECUs. I have given up trying to help as it is useless, one day he get it I'm sure...
I have the schematics and he thinks they are wrong because he has a JDM engine and ECU. Yea the colors are different but the pin-outs remain the same, some people just don't understand I guess.
Atleast my shit is wired right!! LOL
Peace
~J
"CHEAP THRILLS"
ARMY AIRBORNE!!!
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
Are there any swap meet NEEDaNEWcar California 0 05-11-2004 11:35 PM
are there any legal and smog passing swaps for a 240 jared240sx 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 02-23-2004 11:17 PM
are there any engine swaps you could do to a sunfire? scyth_0_notic General Discussions 1 08-17-2003 09:17 PM
