Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-27-2003, 03:54 PM
ssgderek ssgderek is offline
1995 Jimmy Erratic idle
I have a 95` Jimmy (fuel injected )that is having some idling trouble. If I am not pressing the accelerator, the engine will rev up and down, like I am tapping on the gas pedal. The RPMs jump between about 500 to 1000. I cant find any vaccum leaks and I just replaced the air filter, the fuel filter, and the plugs. I also changed the oil and put some STP fuel system cleaner in the gas. I think it may be the TPS or something like that, because as long as I am pressing the accellerator, even if it is very lightly, the truck runs fine. The service engine soon light comes on too. It does this everytime I crank the truck, but not always right away. It does it when it is hot or cold. Any ideas?
Old 10-28-2003, 06:09 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 1995 Jimmy Erratic idle
First thing is to find out what code is stored...this may lead to or pinpoint your problem.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-27-2003, 03:00 PM
salleyne salleyne is offline
You may have an egr valve problem. I have a 95 jimmy and the same thing happened to my truck where the egr valve had to be replaced. I believe this is a common occurebce for this model. Good Luck taking care of this one.
Old 11-24-2004, 02:18 AM
coronaroma coronaroma is offline
Re: Re: 1995 Jimmy Erratic idle
try cleaning out you IAC valve take it out and clean it with an air compressor
Old 11-27-2004, 04:05 PM
JackDaniels386 JackDaniels386 is offline
I had the same problem, and like salleyne said, it was my EGR. just take the 2 bolts on it off, and pull it off and soak it in some carbeurator cleaner. the darn thing always gets carbon all up in it that gives it problems all the time. If this doesn't solve it, try replacing your PCV valve.
Old 11-27-2004, 06:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
1.) Check the CPI injector for leaking.
2.) Clean and reinstall the EGR valve.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-14-2004, 03:19 PM
danpaz_uy danpaz_uy is offline
i had the same problem and i solved it cleaning the iac valve with carburator cleaner, good luck
Old 12-14-2004, 03:56 PM
BlazerLT's Avatar
AF -Advisor
Yea, in this situation it would work, remove, spray with TB cleaner, scrub with a toothbrush, rinse it with the cleaner, reinstall, reset your computer, restart the truck and put it in gear while stopped for 2 minutes so it can relearn the idle and you should be fine.
2000 Grand Am GT erratic idle when warm Help? MakeItWork Grand AM 0 06-05-2010 01:34 PM
'94 Ciera erratic idle/ stalls killerhawk70 Cutlass Series 9 01-29-2010 09:40 AM
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 09:32 AM
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 08:31 PM
1995 CPI Erratic Idle AGAIN! BlazerLT Blazer 3 09-05-2004 03:06 PM
