Old 10-27-2003, 12:21 PM
Braywolfpacker Braywolfpacker is offline
Delayed 2-3 upshift 4 cyl auto transmission
1991 Voyager with 3 speed automatic transmission, began gradually having a delay in the 2-3 upshift. Initially, was minor and only occurred cold. With tranny warm, all shifting was fine. Gradually became more severe, but still only on the 2-3 upshift. Have removed transmission, reconditioned the valve body, removed and checked the governor valve(s). Had some slight burring of the valve body transfer plate at one check ball. Front and rear clutches can be actuated with air pressure, fluid shows no sign of metal contamination. Bands do not visibly show wear (viewed with valve body removed). Am currently making a holding bar to remove the transfer gear and check the governor support seal(s). Anyone with any advice on what else to look at? I have not yet decided whether to completely rebuild the transmission (at this point have not removed the oil pump, planetary gears, etc).
88 mustang 2.3 4 cyl lx idle problems littlecolonel Mustang Problem Diagnosis 2 06-19-2008 01:59 AM
97 transport delayed 2-3 shift jj86 Trans Sport 4 12-14-2006 09:49 PM
Delayed 2-3 shift on 1996 Dodge Indy Ram kenlhav Ram Pickup | Ram SRT10 1 08-11-2005 08:04 PM
95 Orvis with 2-3 upshift problem pkellymc Grand Cherokee | Grand Cherokee SRT8 2 03-16-2005 10:17 AM
97 Ram 1500 delayed 2-3 shift when hot noellenchris Ram Pickup | Ram SRT10 6 05-20-2004 03:22 PM
