Old 10-27-2003, 11:16 AM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Lightbulb I think my car is bleeding to death.....
Ok, so on my way back up to school i get the check engine light. I pull over and pop the hood and some white "smoke" is comming out of the engine bay. I look around and notice that a hose is spraying something onto the manifold and making it steam. I super glued it up and everything seemed to be fixed. About an hour later i pull over for some munchies and notice alot more "smoke" comming out from the hood. this time i find that their is a fluid leaking out where the drive shaft meets the front axel. Is this my transmission fluid leaking out? anyone with any help would be greatly appreciated.
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 10-27-2003, 12:45 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
That certainly sounds like tranny fluid to me... What was spraying on your manifold though?
Old 10-27-2003, 12:47 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: I think my car is bleeding to death.....
get that hose replaced too. I don't think that super glue was a wise choice.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 10-27-2003, 01:42 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
If I had to guess I'd say it was coolant. Same thing happened to me a couple years ago. One of my heater hoses cracked & was spraying coolant all over the place. Luckily for me the crack was close to the end of the hose, so I just cut it off at the crack & stretched it to fit....
Old 10-27-2003, 01:49 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: Re: I think my car is bleeding to death.....
Not always the best choice, but super glue will fix just about anything in a bind. Has as much holding power as two pieces of steel welded together (sometimes more) and bonds just about anything instantly (ever gotten super glue on you and tried to wash it off? Notice it doesn't wash off and it starts to bond the chlorine and floride in the water to you? Good super glue that is.)
However for high temp things such as under your hood, you'd better get that hose replaced as soon as possible.
The extra white smoke coming out of the hood when you stopped was probably the rest of what that hose was leaking off burning off the engine.
Honda Enthusiast
Old 10-27-2003, 05:27 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Re: Re: I think my car is bleeding to death.....
It's coolant. If a pin hole sized hole gets in a hose the pressure makes the coolant squirt out like a water gun, hits in the hot engine and vaporizes it and makes white smoke.
Old 10-27-2003, 05:37 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Re: Re: Re: I think my car is bleeding to death.....
Water vapour does not turn into smoke!
Didnt any of you people do even basic science at school?
Smoke is suspended particulate matter as the result of imcomplete compustion.
The white vapour that results from super heating water is called steam!
Even the most basicly educated 10 year old should be able to tell the two apart.
Old 10-27-2003, 05:45 PM
Re: Re: Re: Re: Re: I think my car is bleeding to death.....
But the hose isn't squirting water out of it, it's squirting coolant.
Old 10-27-2003, 09:41 PM
what coolant would be leaking from that location? i can tell my car is preforming right, their seems to be a lack of acceleration/torque.....
TEAM CHOZEN
Old 10-27-2003, 10:51 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Where exactly was that hose you glued? Was it down low near the transmission or farther back near the firewall?
Anyway, I think you have one of the following problems or both:
1. A pin hole leak or crack in one of your small coolant lines
2. Your transmission vent tube is blocked causing excess pressure to build up in the transmission housing causing oil to be pushed past the axel seals. The oil is then slung by the spinning axel hitting hot engine parts causing smoke.
Old 10-28-2003, 10:15 AM
Ok, i got the needle size hole first comming from a tube. If u are looking straight down on the engine bay its at the behinde the top left corner of the engine.
after i glued the tube it started leaking from the axel joint area.
TEAM CHOZEN
Old 10-28-2003, 07:48 PM
AHEM!
TEAM CHOZEN
Old 10-28-2003, 09:28 PM
johnb16a2's Avatar
OK, you've got a coolant line leaking and even though you have glued most of the hole shut there is still a leak and hot coolant is landing on to your transmission making it LOOK like there is smoke coming from the transmission. That's my theory and I'm stickin' to it.
Old 10-28-2003, 10:02 PM
u can see the fluid coming out of the conection
TEAM CHOZEN
Old 10-29-2003, 09:52 AM
johnb16a2's Avatar
OK, then I'm falling back to my original theory (modified), if the fluid is reddish or brownish, you have two problems:
1. Leaking coolant form that hose
2. The transmission vent tube is clogged and/or your axel seals are shot.
And that's my final answer.
Bleeding 2001 F'in Brakes Nickboudro Silverado 8 02-08-2010 08:09 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
Drive Your Car to Death, Save $31,000 xfeejayx Camry/Camry Hybrid/Vista 2 09-07-2007 11:06 AM
i luv this car to death 92pontiacbonny J 0 08-01-2005 06:39 PM
