Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 10-27-2003, 09:18 AM
sergent sergent is offline
Send a message via ICQ to sergent Send a message via AIM to sergent Send a message via Yahoo to sergent
remote starter jetta diesel
Hi,
trying to install a remote starter on my new 94 jetta Marathon 1.9 T
was working good before on my jetta 1.6 89
cannot find the tach wire,,
tried at the Led light in the dash but not working,,
same error code on the remote starter,, it say s <<no signal, bad tach wire>>
somebody said to try the white wire coming out of transmission, a 3 wire..just beside or close to the spedometer wire..
doesnt work..
any suggestion to get a tach signal..,,
I already tryed a tach gadget generator but no good,,
to much difference when, -25C and +20 C on the tach signal ..
Old 10-30-2003, 09:36 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: remote starter jetta diesel
Originally Posted by sergent
Hi,
doesnt work..
Go to any injector wire that is not the same as the others.
Old 10-31-2003, 08:23 PM
humm..
you mean other wire from..
diesel..?
sorry for my poor english..
dont understand,,
can You explain,,
thanks..
Old 11-01-2003, 08:36 AM
Re: Re: remote starter jetta diesel
Use one of the wires going to the fuel injector.
Old 11-02-2003, 08:54 PM
using one of the wire going to the injector..
dont know what you mean,,
it s a diesel..
1 pump ( selenoid control the input of fuel) who pump up the injector..
a mechanical pump.. so if I jump (put 12v.+ ) on the selenoid all the time ,, the car never stop..
there is no wire at all.. no wire to injector.. its a mechanical injector..
the only wire is going to activate the selenoid to let the fuel comming in the put..
need more information..
sorry dont understand.. can you explain again..
thanks..
Old 11-03-2003, 07:57 PM
it s a diesel..
thanks..
You sure the injector is mechanical? This should be the nossel that sprays fuel into either the intake manifold or cyl. head. If you can not find that, just go to voltage sense on the remote or maybe find a crank sensor.
Jetta Diesel in a 70' Charger? Shpuker Engineering/ Technical 9 08-19-2010 02:51 PM
Jetta Diesel in a 70' Charger? Shpuker Car Rumors & Concepts 6 02-28-2010 06:15 PM
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 09:36 AM
2009 Jetta Diesel in a 1970 Charger? Shpuker Classic Cars 2 07-27-2009 06:21 PM
diesel engine remote starters dtfloydecu F Series 4 05-03-2004 08:21 PM
