Old 10-27-2003, 07:35 AM
CJD CJD is offline
Angry tired of stalling....very disgusted
i have a 92 grand prix le. it stalls out after about half mile of driving
u can't restart for a half hour or more afterwards. the same thing happens again and again..any advice would help ....
Old 10-27-2003, 08:27 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: tired of stalling....very disgusted
First thing we have to find out is what is missing when it stalls and wont restart....fuel or spark...this will lead us in the right direction..
When the engine stalls and wont restart, remove 1 plug wire from the plug and place the boot close to a ground (engine metal) spin the engine over and see if you hear or see spark jumping out of the boot.
After that, depress the shrader valve on the fuel line and see if gas sprays out (be careful, gas is under high pressure)
Post the results and we will go from there
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-27-2003, 03:16 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: Re: tired of stalling....very disgusted
I agree
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 10-28-2003, 08:52 AM
97gtp 97gtp is offline
I'm in the same situation. My 97 GTP has been in my garage for two weeks. My car has 103,000. I drove it 2 Sundays ago and went to leave someones house and the engine turned over ran for 5 secs then shut down.
I went and bought a new fuel filter $13.26, new fuel Pump $302.83 I installed both of them over this passed weekend the problems still not fixed... Last night I checked the fuel pump relay and the INJ fuse no problems there. Did you remove your air box cover and try and spray carb cleaner in there??? That will at least let you know if it's indeed a fuel problem.. You should start your car and have someone spray carb cleaner in there, don't give it any gas see if your car stays running.
If it stays running then you have a sensor problem, You may have a crankshaft position sensor problem it turns the pulley and the fly wheel so your engine engages and runs. I have had my car for 4 years and at 81,000 miles I did have to replace the alternator. Do you have a tester to hook up to your alternator to see if your alternator has any power. If you don't have the tool some local auto zone stores will lend you one. Your best bet would be to find some one you now that has a OTC testor or a TEch 2 scanner. Which will diagnos any problems. The crankshaft sensor is located behind your right front wheel, you will have to take your wheel off and then the splash guard off. You will see a pulley with a bolt right in the center, this is your crankshaft balancer remove that then the sensor is right behind it. If you have a chitlons repair manual then it will show you how to remove the part and in stal the sensor. I actually had my car in the paper for sale and a guy came last night to look at it even though its not running and told me he would take it with the crankshaft sensor and he would fix it.. I MANAGED TO GET RID OF IT FOR A 1995 Z71 STEPSIDE CHEVY .
If you have any questions feel free to email me @ [email protected]
Rebecca
Old 10-28-2003, 09:36 AM
GMMerlin's Avatar
I know stuff
Rebecca
If you spend a little time checking the basics and find out what is missing from the air,fuel,spark and compression combination that makes the engine run, you can narrow down what is at fault.
Diagnositics takes a little time, but it can and will save you money in the long run.
Why spend money on parts you don't need only to have the frustration of finding out that your problem is not fixed.
GM WCT
PM Me for details
New tires installed - very impressed. skyzend Blazer 4 11-30-2010 08:38 PM
F/S 22" and 23" Tires, Sweet, very low prices 73'Camaro C/K 1 08-25-2004 01:17 AM
